no prob,
also, if there's hum, make sure both amps are plugged into the same wall receptacle/power strip, etc.
no prob,
As I said earlier, putting the amps in series (in this case from the input of the first amp, to the input of the second amp) allows for experimenting with gain staging. And what I mean by that, is that you can kind of use the first amp as a preamp or just an effects unit. Think of the first amp as a pedal, thats basically what you are doing. You can't do this with a A/B switcher.Larsongs wrote: ↑Mon Mar 11, 2019 6:23 amQuestion? What are you trying to accomplish Sound wise? Is there something different re; the Sound going from Guitar Input from Amp #1 to Guitar Input on Amp #2 than it would be using an A/B Box? (Other than the A/B Box being able to switch from one Amp to the other Amp or play both simultaneously?)
Also, do the different Amps individual Ratings & Ohm Ratings enter into it?
Thanks,
L
What switchers do you use? I need a dual amp both on so I was thinking the Tonebone JX2 or Lehle Little Dual.somanytoys wrote: ↑Mon Mar 18, 2019 8:28 amI always run multiple amps, 2 at a minimum and right now usually 5 on guitar.
But I always run them in parallel, never in series I typically use very good splitters that have an isolation transformer and a phase inverter for the 2nd amp (much easier for me than rewiring speaker leads). I've read a lot about chaining amps in series, usually way in the past (like EVH, Tom Schultz, etc.) but I'm not overly confident that's something that I really want/need to do in this day and age, especially at the lower volumes that I usually play at. Maybe I'm missing out on something really cool, though.
I use several types of preamps with my bass amps, but I only either go preamp into a poweramp or preamp into the receive jack of the loop of a regular head, bypassing its preamp. I have a Rusty Box pedal, that is either a pedal or a preamp, and it specifically says not to use it in preamp mode into another preamp, because of the signal it generates. But that's opposite of what it sounds like yours is set up for.
Anyway, it seems like the main thing to note in your situation would be what levels the Peavey is pushing out of that signal (z level or power?), and if it's okay in general to load that type of signal into a tube preamp. It sounds like it should be within tolerance if it's specifically made to do that, but I would be a bit scared. It seems like it would be pretty easy to overload the pre-amp if it puts out more signal than the preamp can handle. I would think that would go before the power amp stage, but I don't know. Tubes can also be much more delicate and reactionary than solid state equipment.
If it's something that you want to continue to do, and you have any issues with hum or phase, I would suggest getting something with a phase inverter. I don't konw if you would need an isolating transformer as well, and I guess it doesn't necessarily have to be an AB/Y splitter for a series application. But if you ever decide to go parallel instead, that's a good way to do it.
I’ve heard conflicting things about the Lehle and personally I think the options to flip phase and ground loops on the Radial seems to be better. I do like the dual inputs of the Little Dual, but no buffer sucks for me cos I run both the amps on all the time. My understanding is that there be tone loss and volume loss with the Lehle.ziess wrote: ↑Tue Mar 19, 2019 12:11 amI can't speak for the JX2, but I've got both the older (non-boost equipped) Tonebone and a Lehle Little dual. The Lehle is much nicer, better build quality and switches and I'd wager slightly (though it is slight) more transparent when using the isolation transformer.
Looks cooler too.
Tommy.
Awesome! I’m pushing four for my Ultimate Surf Tone (2x Showmans and 2x Twins) and I’ve been holding off getting a big isolation transformer, and instead got several HumX isolators. One Showman is plugged straight to the wall, the other three, the reverb tank, and the Gigrig pedal power are all plugged in through HumX adaptors.somanytoys wrote: ↑Mon Mar 18, 2019 8:28 amI always run them in parallel, never in series I typically use very good splitters that have an isolation transformer and a phase inverter for the 2nd amp (much easier for me than rewiring speaker leads).
Since you already have the HumX adapters, you may want to try the Radial Headlight, I think it's between $150 - 200. Channels 2-4 have individual polarity switches, so you should be able to reverse the polarity on the one Showman, or any of the others if they happen to get out of phase. Just be sure that the amp fed from channel 1 isn't reversed, and you'll have control over the other 3 amps' polarity.DeathJag wrote: ↑Fri Mar 22, 2019 1:13 pmAwesome! I’m pushing four for my Ultimate Surf Tone (2x Showmans and 2x Twins) and I’ve been holding off getting a big isolation transformer, and instead got several HumX isolators. One Showman is plugged straight to the wall, the other three, the reverb tank, and the Gigrig pedal power are all plugged in through HumX adaptors.somanytoys wrote: ↑Mon Mar 18, 2019 8:28 amI always run them in parallel, never in series I typically use very good splitters that have an isolation transformer and a phase inverter for the 2nd amp (much easier for me than rewiring speaker leads).
I’m curious what gear you’re using? The phase reverse too, I think one Showman is wired reverse.
I don't know enough about this to give you an answer. That just seems counter-intuitive to me, because they're all inputs, but I'm no expert and some amps may be built for doing exactly that.
I do notice a drop in volume in each amp for bass, as I turn another channel on, using the Lehle 1 @ 3, and probably losing some tone along with it as well. The Little Dual may not do this since it has an isolated transformer, I don't know.spiffy chap wrote: ↑Tue Mar 19, 2019 5:03 pmI’ve heard conflicting things about the Lehle and personally I think the options to flip phase and ground loops on the Radial seems to be better. I do like the dual inputs of the Little Dual, but no buffer sucks for me cos I run both the amps on all the time. My understanding is that there be tone loss and volume loss with the Lehle.ziess wrote: ↑Tue Mar 19, 2019 12:11 amI can't speak for the JX2, but I've got both the older (non-boost equipped) Tonebone and a Lehle Little dual. The Lehle is much nicer, better build quality and switches and I'd wager slightly (though it is slight) more transparent when using the isolation transformer.
Looks cooler too.
Tommy.
Wow thanks a lot for that sir! It’s a lot to digest, but I look forward to doing so!
