Noisy Wiring/Amps?
Make it loud here.
Danley
Noisy Wiring/Amps?
Post by Danley » Fri Jul 12, 2019 11:53 am
So to start, I have something weird going on in the wiring of my house. I've pretty much narrowed this down, because I have a battery powered/AC amp that has tons of buzz when I use wall power (have even tried reversing the plug polarity, with no good result.) Yet when using battery power all my guitars play through it with no noise. I also don't hear any noise other than 60 cycle hum where applicable when playing through an audio interface.
I only have this issue when plugged into the wall, BUT: for whatever reason my Jackson Soloist is still totally noise free using AC power; and my Jazzmaster (even with RWRP/both pickups selected) makes much more noise than the rest. My other guitars (both humbucker and single-equipped) make a more marginal amount of noise, but are still noisy. So takeaways:
  • Would a power conditioner solve for the noise somewhat (given the two amps in question are a 5 watt Vox AC4 and a Silverface Champ?) Should I be looking toward another solution first?
  • Why would certain guitars be affected by the wall issue more than others? I get that Jazzmaster pickups are huge noise antennas, but shouldn't it not matter if I have RWRP and both pickups engaged?
  • I'm sure this isn't a ground issue with the guitars - I just totally ripped apart my Jazzmaster's wiring and checked all possible places, bridge etc. for ground continuity with a multimeter. I even created (then repaired) a ground issue just to experiment and understand how a ground buzz would come through, and it's not that
timtam
Re: Noisy Wiring/Amps?
Post by timtam » Fri Jul 12, 2019 9:39 pm
These things are difficult ... semi-random thoughts ...
That does suggest that the noise source is not airborne EMI from non-amp sources getting into the guitar, as that would be similar when on batteries. When on AC power and noisy, is there much of a noise difference when touching guitar metal (ie grounding yourself) or not ?
Can you battery-power either amp or just one ? Was the other amp AC-connected and ON at the same time as battery-powered rig was quiet ?
Soloist is HB or SC model ? In any case, this suggests either that it's not a systemic power problem (somewhat contrary to battery findings, ), or that that guitar is very immune (HB ? shielding ?).
JM is direct into amp with no effects and amp is direct into wall (no power boards or extension cords) ?
Same noise with both amps ?
Has JM been modded ? ie have you verified RWRP ? Is it shielded ? Is shielding grounded ?
I assume different cables tried ?
Danley
Post by Danley » Fri Jul 12, 2019 10:08 pm
A bit of difference (less noisy) when I touch strings/metal using AC - but no difference using battery (still quiet.)
I wasn't totally clear in the post - but both the Vox and Champ are only AC, the battery powered amp (that I can also plug in AC using an adapter) is a small portable test amp I have on my workbench. I didn't test both the battery and AC at the same time, though I went back and forth many times in a short span.
Soloist is humbuckers. I have one other HH guitar where the noise still does come through somewhat on AC, but this Soloist is absolutely silent. The single coil guitars that are RWRP still have a bit of noise as well - not as much as the Jazzmaster though (worth it to mention - my two other Jazzmasters are also in that middle-area of being prob. too noisy using AC, but less so than the particular Jazzmaster I'm talking about.)
Yep - no pedals (even tried using one as a buffer, no dice) straight into amp, amp direct into the wall. Same noise with both amps. JM has def. been modded; it's an American Special which did not originally have shielding (so I added copper tape.) Grounding works and is connected to the copper, has continuity through my multimeter - I seriously checked everywhere I could think of, re-did solders etc. It's definitely RWRP, using the battery power (or interface) I get 60 cycle with individual pickups- but silent on 'both.' Come to think of it I take it to my guitar teacher's studio and play through his amp no problem.
It's strange - for a fairly long while my amps were packed up while work was being done on the house (no electrical though,) and I only used my interface to play. Now I pulled the amps out and I'm hearing this.
