So I haven't had a ton of time to post, but completed the recap on this amp. It sounds infinitely better! Its louder, sounds more full-range and its biasing properly, although I still have a bias pot installed until I find a happy medium with the tubes I'm using.
Here's some pics of the process for anyone who's interested.
I wanted to try to salvage the look of the bog orange Astrons on the board, so I attempted a "restuff".
Removing the original cap from the cardboard sleeve.
Easy enough...
Here it is with the new (much smaller) Sprague Atom inside. I used double sided velcro to hold it in place.
I capped the end off with a rubber grommet just to give it a more finished look. I left the original solder joint in tact. If I find my new solder joint doesn't hold up I'll break the original solder and put it directly in the eyelet.
