Does this type of Loop pedal exist?
Everyone needs a stompbox.
X-Ray Spex
Post by X-Ray Spex » Tue Jan 23, 2024 12:48 am
Been trying to figure out if this even exists or if the technology isn't there yet without going into MIDI interface shenanigans.
- You record a piece of music.
- You can then manually adjust the speed of the playback sample after the fact WITHOUT the sample becoming pitched up or down.
Is this a thing or am I dreaming? I know you can adjust it on other loop pedals but it always creates sample pitching.
ryland
Re: Does this type of Loop pedal exist?
Post by ryland » Tue Jan 23, 2024 7:50 am
I'm 90% sure that the RC-600 does this.
npfrs
Post by npfrs » Fri Jan 26, 2024 6:41 pm
This is called time-stretching on most samplers and, depending on how much long (or shorter) you change it to be you'll start to notice artifacts, although that can be kinda fun.
I can't think of a loop pedal that does this off the top of my head but knowing the terminology may help you find one capable of it. Cheers!
sessylU
Post by sessylU » Sun Jan 28, 2024 1:25 pm
EHX Memory Man with Hazarai does this.
It does loads of other things, too, and it's only a pretty good looper as opposed to a full on, fully featured looper, but if you wanted something that took care of this problem, and also got loads of other delay and spaceship sounds, it could be the one.
a total idiot jackass
BoringPostcards
Post by BoringPostcards » Sun Jan 28, 2024 2:29 pm
Yes. Grab one of these, if you can find one for a decent price. I had one back in the day, and regretfully didn’t keep it.
sessylU
Post by sessylU » Mon Jan 29, 2024 11:17 am
Huh, hadn't realised they'd appreciated a bit in value. Mine has pretty much indispensable for the last decade or so, until recently when I got an M13 for a lot of my reverb and delay sounds. The M13 is a different thing, but it's definitely more flexible and easy to work in a band setting.
I'll definitely have uses again for the Hazarai, I probably just need to spend time experimenting again. I feel like a lot of the time I spend with my pedalboard these days feels more like programming or problem solving, instead of exploring.
Did you do a demo of it aaaaaaages ago, back on Shortscale? I think I have half a memory of something like that... I might be mixing you up with someone else.
BoringPostcards
Post by BoringPostcards » Mon Jan 29, 2024 12:36 pm
I definitely didn’t make a demo of the hazarai, but I did post a few others on ShortScale back in the day. Mostly for MBM stuff.
X-Ray Spex
Post by X-Ray Spex » Tue Jan 30, 2024 2:45 am
Hazarai it is! Thank you all so much for the info :)
CorporateDisguise
Post by CorporateDisguise » Tue Feb 06, 2024 12:15 pm
When you get it, make sure to play with the 1sec+rev. Truly magical! When you hold down the tap button, it repeats the last few seconds of playing in reverse.
Also, while the looper isn’t crazy sophisticated, it has everything you could want in a basic looper. It also does a great morphing loop as you add layers.
I’ve been trying to get rid of this pedal off my board for years, but I’ve made to many of its niche sounds part of my repertoire, so I guess I’m stuck with it……
fever606
Post by fever606 » Sat Feb 10, 2024 6:18 am
I realize this might be late to the party, but the Red Panda Tensor can adjust time and pitch independently…
ryland
Post by ryland » Tue Feb 13, 2024 8:22 am
Plus it's the best pedal ever made.
jorri
Post by jorri » Sun Feb 18, 2024 5:37 pm
Yes but only by tap tempo on the footswitch. The knob causes sample shifting. I mainly use it as a weird effect because it can be quite a lo fi time-stretch (or maybe my time stretches are just purposefully extreme!). And i'd probably want other pedals but no one has the looper functions (1440 close, just missed time-stretch and a filter.) and reverse delay (canyon close for standard reverse delay, doesn't do the decay knob weirdness which is what i want it for), and i'd say another pedal because of the infamous volume droppage and the 'hold-to-loop' although there are some sound-scape things that has advantages (dropping in short clips) it a pain to be in time compared to 'press-to-loop start and stop' like most pedals are.
