Dillhole-level hardware MIDI routing question
Dave
Post by Dave » Wed Apr 29, 2020 10:12 am
:fp:
Ok, I guess 1982 is as advanced my mind gets with cutting edge midi technology. I’ve got 2 god damned midi cables. I want to send RX11 clock to my R3 AS WELL AS keyboard from my 106.
Here’s what I’m attempting-
RX11 midi out -> 106 midi through
106 midi out -> R3 midi in
However the R3 does not appear to be receiving RX11 clock. I’m assuming I just don’t actually understand midi through/any fucking thing, but regardless I’m not sure how to send 2 midi signals into that R3 from independent sources.
The shitty R3 is programmed for an arpeggiated bass in the lower octave and all I want is for it to arpeggiate locked to the tempo of the shitty RX11 but I’m too shitty at synths to play 2 separate keyboards, so I want to play Juno’s nice bigass 61 key setup.
Telliot
Re: Dillhole-level hardware MIDI routing question
Post by Telliot » Wed Apr 29, 2020 12:07 pm
Forgive me for asking the obvious, but do you have your midi clocks set to ‘in’ on the R3 and Juno, and ‘send’ on the RX11? Does the RX11 have a clock out, or does it only send midi notes?
Dave
Post by Dave » Wed Apr 29, 2020 12:36 pm
Clock set to external midi on R3
Juno doesn’t really have a bpm clock so I guess no?
RX11 sends clock by default, though it also triggers notes with each drum beat which I don’t know how to disable.
Telliot
Post by Telliot » Wed Apr 29, 2020 1:16 pm
Do you have the manual for the RX11? On pg 26 it explains different sync functions, including clock out.
Telliot
Post by Telliot » Thu Apr 30, 2020 11:05 am
Any luck?
Dave
Post by Dave » Thu Apr 30, 2020 12:32 pm
I re-arranged it in a more logical way with partial success-
Juno 106 midi out-> R3 midi in-> R3 midi out -> RX11 midi in
Then I set RX-11 for external clock and let the arpeggiator on the R3 dictate tempo.
It sort of worked but it wouldn’t quantize my arpeggiated bass so if I happened to trigger the low note slightly off tempo it would just take off out of time. If I control R3’s tempo with RX11’s clock that doesn’t happen, I set arpeggiator to 1/8ths and it quantizes it for me so it’s locked mint. That’s why I’d like to let the RX dictate timing and Juno dictate note information, somehow simultaneously.
