think it's flipped for a lefty
"Why did you do it? Why did you do this thing to me?"
- MechaBulletBill
- sal paradise
Re: "Why did you do it? Why did you do this thing to me?"
- Pacafeliz
Yahoooo
- DrippyReverbTremolo
Save me Jebus.
- will
That Gibson reminded me of Pat's Telecaster - all hollow on the inside!
tqi wrote: ↑Sat Dec 30, 2023 2:50 amThat doesn't look too bad. Compare that to Super Stumpy.
I sure as hell wouldn't pay that money for it, but someone skilled should be able to clean up that route, and with a bit of cnc cunning, machine an exact plug to restore it. Someone very skilled could probably do it by hand. Will? How's your budget this month?
Especially with an opaque finish... look, you all know what I'm about.
You'd never be able to tell!
- will
Very simple to remedy, but seeing this item on eBay made me giggle:
- X-Ray Spex
- Pacafeliz
what the FUCK man????!!!X-Ray Spex wrote: ↑Wed Jan 10, 2024 12:32 amJust why, awful hack job on a beautiful piece of Kramer history.
At least you could maybe refin it?
Somebody tried to actually kill it and stab it with a knife or what?!
- JVG
- Pacafeliz
dude it'd look like you're humping the guitar while it wails...
Actually, not a bad idea
- sal paradise
First entry for a scratchplate? Not even vintage. The mind boggles. Unless you’re in a wedding band, I guess. In that case, an overly complex nonsense would begin to make sense …
EBay linky
EBay linky
- ldp54002
I'll own up to making abominations like that in my day. I once build a parts Strat with triple humbuckers and a Floyd Rose. Each of the pickups was wired to toggles for split, series/parallel and out of phase. My wife called it the "most extra" guitar I've ever had.sal paradise wrote: ↑Wed Jan 10, 2024 4:18 amFirst entry for a scratchplate? Not even vintage. The mind boggles. Unless you’re in a wedding band, I guess. In that case, an overly complex nonsense would begin to make sense …
EBay linky
To paraphrase Ian Malcolm, I built it more because I could, not because I should.
- GilmourD
Honestly, I actually don't see a problem with that pickguard. It's versatile. The P-Rails have three distinct sounds by design (full humbucker, P90 coil, rail coil) without even considering parallel and internal phasing. Not sure what the third switch is for since the Vintage Rails isn't splitableldp54002 wrote: ↑Wed Jan 10, 2024 7:23 amI'll own up to making abominations like that in my day. I once build a parts Strat with triple humbuckers and a Floyd Rose. Each of the pickups was wired to toggles for split, series/parallel and out of phase. My wife called it the "most extra" guitar I've ever had.sal paradise wrote: ↑Wed Jan 10, 2024 4:18 amFirst entry for a scratchplate? Not even vintage. The mind boggles. Unless you’re in a wedding band, I guess. In that case, an overly complex nonsense would begin to make sense …
EBay linky
- MrFingers
Probably a master-switch that allows you to add the neck or bridge pickup to any sound already blended by the 5-way switch. So it allows you to do all 3 pickups together, or neck+bridge together which you normally can't do on a Strat.
