59 Jazzmaster humming in all positions - what to do?
- Guitarman555
I bought a 59 jazzmaster, repaired whammy, but there is another problem (I dont know if it happend after my opening the pickguard or was already when I bought.). It hums in all positions, including middle. Which is most obvious on the middle position, which is normally at jazzies and all guitars much lower than on the bridge or neck.... I think it will be a wire from the input not well connected, shielding, but not sure at all... Does anybody know? Many thanks.
- PJazzmaster
Re: 59 Jazzmaster humming in all positions - what to do?
59? Worst year! They are all bad, send it to me and you‘ll get my perfectly working Squier instead. I need some old clothwire and wood for some other project so I could for sure find use for some of the crappy 59 parts. Deal?
Okok, sorry. I couldn‘t resist. Did it happen after removing the pickguard. It could be that a pot, the input jack or the 3 way switch is touching the shielding. Check that first, ok?
- Marc
Check the ground wire that connects to the tremolo which is just sandwiched between the body and the trem plate. If not that, it could be a faulty pot or a bad cap. I don't know if your guitar has virgin solder joints - if it has it could be a problem as you won't want to start taking things out of the circuit to see if it isolates the hum. I guess you could give the solder-joints a but of a prod with a chop stick to see if that makes a difference and just needs reflowing.
- Guitarman555
Hey, I am not sure if I understend both possibles problem cases: 1. So the ground wire should lead from tremolo(what part of tremolo(tail?) and should be solder jointed where exctly?) and and where excactly between trem plate and body it should end and to what place connected ? I will check it then.Marc wrote: ↑Sun Aug 05, 2018 3:31 amCheck the ground wire that connects to the tremolo which is just sandwiched between the body and the trem plate. If not that, it could be a faulty pot or a bad cap. I don't know if your guitar has virgin solder joints - if it has it could be a problem as you won't want to start taking things out of the circuit to see if it isolates the hum. I guess you could give the solder-joints a but of a prod with a chop stick to see if that makes a difference and just needs reflowing.
2. And for the joints - you mean to check the solder joints and if they are ok means that then it could be a cap, or other things in circuit?
3. This sentence I cann´t understant - I am not English native, sorry: "I guess you could give the solder-joints a but of a prod with a chop stick to see if that makes a difference and just needs reflowing." Could you try to use different words? Many thanks to you!
- Guitarman555
PJazzmaster wrote: ↑Sun Aug 05, 2018 2:48 am59? Worst year! They are all bad, send it to me and you‘ll get my perfectly working Squier instead. I need some old clothwire and wood for some other project so I could for sure find use for some of the crappy 59 parts. Deal?
- bencrit
Here is some help with the last sentence.Guitarman555 wrote: ↑Sun Aug 05, 2018 5:08 amHey, I am not sure if I understend both possibles problem cases: 1. So the ground wire should lead from tremolo(what part of tremolo(tail?) and should be solder jointed where exctly?) and and where excactly between trem plate and body it should end and to what place connected ? I will check it then.Marc wrote: ↑Sun Aug 05, 2018 3:31 amCheck the ground wire that connects to the tremolo which is just sandwiched between the body and the trem plate. If not that, it could be a faulty pot or a bad cap. I don't know if your guitar has virgin solder joints - if it has it could be a problem as you won't want to start taking things out of the circuit to see if it isolates the hum. I guess you could give the solder-joints a but of a prod with a chop stick to see if that makes a difference and just needs reflowing.
What he means is that you could use a small wooden stick (like a chopstick or a toothpick) to gently press on the solder joints to see if anything is loose.
I would be very careful doing that.
More likely you are having some kind of grounding problem.
If you touch part of the metal on your amplifier while holding the guitar, does that remove the hum or buzz? You can also touch the metal part of the cable plugged into the input jack. It that takes it away, its probably a grounding problem.
Also, make sure to try several amps so that you know the problem is definitely with the guitar, and not on the amplifier.
- Guitarman555
Many thanks. Yes, the problem stays will all amps. In my second Jazzmaster, which is working perfect, when I touch the strings, the buzz is gone (maybe this is connected to your mentioned grounding wire to trem plate). In the 59 Jazzy that has the buzzing poblem, when I touch the string, nothing happens. But when I touch the jack close the input to the guitar, buzz disappers. What do you think? I bet grounding and to control wire connection on trem plate?bencrit wrote: ↑Sun Aug 05, 2018 6:44 amHere is some help with the last sentence.Guitarman555 wrote: ↑Sun Aug 05, 2018 5:08 amHey, I am not sure if I understend both possibles problem cases: 1. So the ground wire should lead from tremolo(what part of tremolo(tail?) and should be solder jointed where exctly?) and and where excactly between trem plate and body it should end and to what place connected ? I will check it then.Marc wrote: ↑Sun Aug 05, 2018 3:31 amCheck the ground wire that connects to the tremolo which is just sandwiched between the body and the trem plate. If not that, it could be a faulty pot or a bad cap. I don't know if your guitar has virgin solder joints - if it has it could be a problem as you won't want to start taking things out of the circuit to see if it isolates the hum. I guess you could give the solder-joints a but of a prod with a chop stick to see if that makes a difference and just needs reflowing.
That is the correct pattern - your body is grounded when you touch grounded metal. Therefore the EMI hum you attracted is reduced.Guitarman555 wrote: ↑Sun Aug 05, 2018 7:46 amIn my second Jazzmaster, which is working perfect, when I touch the strings, the buzz is gone (maybe this is connected to your mentioned grounding wire to trem plate).
Sounds like the trem/bridge/strings are not grounded. To test, run a wire outside the guitar from the metal jack cover to the trem. If that is the problem, the hum should reduce like in your other guitar.Guitarman555 wrote: ↑Sun Aug 05, 2018 7:46 am
I am not 100% familiar with how 59s were grounded. Could be a ground wire to the trem cavity or a string thimble, or both. Since the bridge and trem are connected by the strings, only one needs a ground wire in order to ground both (unless you have non-metallic saddles). If it has a pickguard shield that needs to be grounded too.
Being a vintage instrument (unmodified ?), I would send it to someone who is used to working on vintage jazzmasters.
- Guitarman555
Hey, Tim, I will check it, so if I understand, when I connect with a wire outside of guitar input and tremolo together and after if all works properly, the problem is grounding. Does anybody know, how grounding in 59 jazzmaster is done? Where exactly wire should be connected to tremolo and where exactly to input?timtam wrote: ↑Sun Aug 05, 2018 5:20 pmThat is the correct pattern - your body is grounded when you touch grounded metal. Therefore the EMI hum you attracted is reduced.Guitarman555 wrote: ↑Sun Aug 05, 2018 7:46 amIn my second Jazzmaster, which is working perfect, when I touch the strings, the buzz is gone (maybe this is connected to your mentioned grounding wire to trem plate).
Yes, connect something like the green test lead shown here.
https://www.thegearpage.net/board/index ... 1533847600
If the hum goes away, then a lack of trem/bridge/string grounding is the problem. If the hum doesn't go away, it's some other problem. Take it to a good tech.
If ground is the problem, open up the trem cavity. If you see a wire, then that's how the trem is supposed to be grounded. It should probably be sandwiched between the trem and the body, so as to make good contact with the trem. If it's not, fix it. The other end of that wire should be connected to a ground point somewhere in the main cavity - back of a pot, output jack, or (grounded) brass shielding plate; it doesn't matter which one. If the trem ground was already touching the trem, then the cavity ground connection has probably been lost. It would need to be restored by soldering. If the ground wire connection looks OK already, take it to a tech to find the real problem.
If there is no trem ground wire you could add one, but since it's a vintage instrument I wouldn't. The true ground will be somewhere else, maybe the bridge thimble hole. That's hard to see without taking the thimble out. So look for a wire coming into the main control cavity through the side wall near the thimble. Re-solder that wire's ground connection to any ground point in the cavity if its connection there is broken. If instead the connection looks to be OK, take it to a tech.
BTW if you have a multimeter this whole thing will be mech easier. You can test for continuity (approx 0 ohms resistance) between the trem and the ground tab on the output jack.
BTW if the guitar is an unmodified vintage instrument and you make changes to solder joints, you will decrease its value in some people's eyes.
- Marc
Sorry I've been away.... just wanted to add that if the ground leading to the tremolo tailpiece looks like an old guitar string that is what Fender sometimes used on Jms and is original rather than someone's idea of a quick repair!
- Guitarman555
Hey, many thanks, so I tried to connect bridge and input jack hole with a wire and everything is exactly like it should be when connected by wire outside. So now I will go inside the guitar. So I will check, wheather there is a wire connecting tremolo cavity(or from the metal saddle bridge thimble) with the main cavity. In the main cavity wire shoud touch the brass shield by solder joint?Guitarman555 wrote: ↑Fri Aug 10, 2018 1:47 amHey, Tim, I will check it, so if I understand, when I connect with a wire outside of guitar input and tremolo together and after if all works properly, the problem is grounding. Does anybody know, how grounding in 59 jazzmaster is done? Where exactly wire should be connected to tremolo and where exactly to input?timtam wrote: ↑Sun Aug 05, 2018 5:20 pmThat is the correct pattern - your body is grounded when you touch grounded metal. Therefore the EMI hum you attracted is reduced.Guitarman555 wrote: ↑Sun Aug 05, 2018 7:46 amIn my second Jazzmaster, which is working perfect, when I touch the strings, the buzz is gone (maybe this is connected to your mentioned grounding wire to trem plate).
- Guitarman555
Hey, many thanks, so I tried to connect bridge and input jack hole with a wire and everything is exactly like it should be when connected by wire outside. So now I will go inside the guitar. So I will check, wheather there is a wire connecting tremolo cavity(or from the metal saddle bridge thimble) with the main cavity. In the main cavity wire shoud touch the brass shield by solder joint?timtam wrote: ↑Fri Aug 10, 2018 5:23 amYes, connect something like the green test lead shown here.
OK .. if I understand you correctly, you ran a wire outside the guitar from bridge to output jack and the hum went away. So the ground connection is missing or broken inside the guitar.
The trem or bridge needs to be grounded . You only need one to be grounded, and that grounds both (since they are connected by the strings). So you need to look at the trem and bridge to find one ground connection.
The ground connection to the bridge could look like the wire on the left here ....
If it is already connected, make sure that the brass plate itself is grounded to the output jack (maybe via the pickguard shielding).
Or instead there could be a little wire contacting grounded pickguard shielding and then going to the bridge thimble, as shown here for the AVRI ...
https://www.fmicassets.com/Damroot/Orig ... A_SISD.pdf
If you can't find any bridge grounds, check the trem for a ground connection ....
If you can't find any ground connections, add one like the left wire above (soldered to the brass plate).
If you're not sure, take pics and post them here.
It's difficult to describe all the possible places to look, as grounding can be done in many ways. Also, you really should have a multimeter to do all this. It will be much easier, and certain. Also, a good tech should be able to figure this out in about a minute.timtam wrote: ↑Fri Aug 10, 2018 5:23 am... open up the trem cavity. If you see a wire, then that's how the trem is supposed to be grounded. It should probably be sandwiched between the trem and the body, so as to make good contact with the trem. If it's not, fix it. The other end of that wire should be connected to a ground point somewhere in the main cavity - back of a pot, output jack, or (grounded) brass shielding plate; it doesn't matter which one. If the trem ground was already touching the trem, then the cavity ground connection has probably been lost. It would need to be restored by soldering.
- Guitarman555
Many Many thaks! I will definetely have multimeter and use it.
"The ground connection to the bridge could look like the wire on the left here ...." - the oppisite end of wire touches the input jack hole, yes? Otherwise everything is clear. I will check wheather wire goes from bridge thimble as pictured, or from tremolo. Both should end in treomlo jack or touch the brass plate shieled, yes? Many thanks!
