Electric XII build
mefgames
Re: Electric XII build
Post by mefgames » Fri Sep 28, 2018 8:18 pm
1/2" bit
Post by zhivago » Fri Sep 28, 2018 11:28 pm
This is looking great! I love the grain on the fretboard...never seen one like that! :) 8)
mefgames
Post by mefgames » Sat Sep 29, 2018 1:38 pm
Fine tuned the rear contour and drilled the headstock for the tuners as well as the body for the neck. Drilling the headstock always makes me a bit tense, but for a 12 string the anxiety is doubled.
rbrcbr
Post by rbrcbr » Mon Oct 01, 2018 2:54 am
Wow, this looks killer so far! Can’t wait to see it all come together! I’d love a custom color XII with a matching headstock - you can go wrong with a good sunburst though!
mefgames
Post by mefgames » Sun Oct 07, 2018 12:08 pm
Headstock decal applied then another coat of Tru-oil applied. The little ding next to the D tuning hole has already been sanded out.
mefgames
Post by mefgames » Wed Oct 10, 2018 3:01 pm
Pickguard template made and PG routed, still need holes for screws and the rotary switch
Body sprayed with sealer, neck getting more Tru-Oil
Rear of body ferrules drilled. I usually prefer them more even, but this is what the plan shows.
mefgames
Post by mefgames » Sun Oct 14, 2018 1:34 pm
3 color burst in progress,
N0_Camping4U
Post by N0_Camping4U » Sun Oct 14, 2018 5:25 pm
This is seriously seriously impressive. You've built this really fast, too.
Can't wait to see the finished product.
Eric Harris: I’m sorry I have so much rage, but you put it on me.
antisymmetric
Post by antisymmetric » Sun Oct 14, 2018 6:07 pm
Nice work!! What's that fingerboard made from?
mefgames
Post by mefgames » Sun Oct 14, 2018 6:22 pm
The fingerboard is Rosewood. It's from Madagascar, not Brazil.
mefgames
Post by mefgames » Mon Oct 15, 2018 12:22 pm
Ongoing progress with my first 3 color burst. Using 1500 grit mesh, I sanded back the red lightly to create uniformity, then using a preval sprayer, I sprayed the black which is currently drying. I will use the same mesh on the black before applying the clear. I got a bit heavy handed with the black around the upper horn, both front and back, which is where the mesh comes in. When it's done, the colors will blend a bit better and show a more equal transition from one to the other.
mefgames
Post by mefgames » Tue Oct 16, 2018 2:09 pm
A little mock up with the PG, I just wanted to see how it was shaping up. I still need to fine tune the PG so it fits the neck and is straight. The second pic is with clear coats applied. Now the wait begins....
mefgames
Post by mefgames » Wed Oct 17, 2018 11:18 am
Another mock up a bit further along.
mefgames
Post by mefgames » Tue Oct 23, 2018 3:21 pm
installed tuners today. Worked on the finish on the body as well. I need to load up the pick guard and drill it for the rotary switch and screws.
tdbajus
Post by tdbajus » Tue Oct 23, 2018 4:48 pm
Swoon.
