Very weird Jag 1963 switch set up
mbene085
Re: Very weird Jag 1963 switch set up
Post by mbene085 » Tue Feb 05, 2019 5:07 am
It sounds like the switches for neck and bridge are working normally, and when they're on together, they're in parallel, which is also the way it should be.
I'll actually check my own jags to see what the resistance reads when you engage the strangle switch, but the fact that the tone thins out makes me think your strangle switch is likely working normally.
It sounds like the rhythm switch may have just been wired to bypass the rhythm tone and volume knobs, switching on the neck pickup but not engaging the separate circuit. This is a fairly common mod.
Guitarman555
Post by Guitarman555 » Sun Feb 10, 2019 8:46 am
Thanks, please let me know as soon you check your Jag. What is weird that rythm switch is still connected to its rythm volume and tone knobs, but has exactly the same tone as neck pickup on lead circuit. If jag´s rythm circuit work same way as jazzy rythm circuit from pre-cbs, it should have its own dark colour of tone, not copy neck setting of lead circuit... What happend there, do you think?
Guitarman555
Post by Guitarman555 » Sun Feb 10, 2019 9:15 am
Another unusual thing: the volume pot on the lead circuit does not work like on pre-cbs jazzys, while turning volume off, it should lose the low frequencies because of the capacitor, but color of the sound surprisingly does not change...or had it the jags differently, like this?
Guitarman555
Post by Guitarman555 » Fri Mar 01, 2019 2:48 pm
Hey, any news? Let me know, I posted more information here to discussion, your answers would be really very appreciated, many thanks!
timtam
Post by timtam » Fri Mar 01, 2019 5:46 pm
I think it's confirmed that it's wierd. ;)
If you want to know why, the next thing would be to open it up and trace the wiring and compare it to the standard circuit.
You could post pics here to confirm that some of the soldering / wiring is no longer vintage. Depending on what and how it's been done (eg is all vintage wire still there), it may be restorable to the standard circuit while still looking vintage, which would restore some value. But a skilled assessment would usually recognize non-vintage soldering compared to totally original work.
Guitarman555
Post by Guitarman555 » Sat Mar 02, 2019 6:54 am
Hey, wiring is oribinal, the old wires, etc, the original cap at the tone control is there too. All the vintage wires at the rythm switch look like should be. But I didn´t measure though. The only measuremnt were done by the pickups, above.
