Questions about a 65 Jaguar
sunburster
Post by sunburster » Sun May 12, 2019 8:15 pm
https://reverb.com/item/23699657-1965-f ... red-w-case
First, does the finish look original? I am skeptical because the wear pattern looks like a fake relic.
Second, the pickups with flat pole pieces (in 1965) is very suspicious. Furthermore, one is a grey bottom and one is a black bottom.
According to the advert:
On the body, all of the electronics work as they should, with unusual flat pole pickups. While the neck pickup has a gray bobbin (the pole pieces are actually staggered "correctly" on the underside of the bobbin, as if the pickup was mounted upside down during original assembly), the bridge pickup has a black bobbin, an abnormality only seen when Fender was transitioning between bobbin materials and still uncommon even in this date range.
I don't buy this explanation, unless someone here can show me it is plausible.
andrewaward
Re: Questions about a 65 Jaguar
Post by andrewaward » Sun May 12, 2019 9:10 pm
The finish on that looks highly suspicious - that would be enough to put me off.
takeittothemall
Post by takeittothemall » Sun May 12, 2019 9:38 pm
I don’t see any issue with the finish. The pick-up explanation didn’t inspire confidence. But, who knows, maybe that’s how the pickups came on a Fender “Jacuar.”
great OSG deals with: ncarey13, skip.
great TGP deals with: drjoel, 12strings, Tim P, angrybandnerd, echobaseone, guitarpkr67, jcampbell331
sookwinder
Post by sookwinder » Sun Jun 02, 2019 3:40 pm
The library at OSG is a useful source of info.
It appears the PAT nos. on the headstock align with early 1965 production, neck without binding.
DES 186,826 PAT. 2,960,900 2,972,923 3,143,028 & PAT. PEND
So given the guitar in question has binding, it would be of concern but not an absolute red flag.
From the library:
FENDER JAGUAR DECAL PAT NO.
1962
DES 186,826 PAT 2,960,900 2,972,923 & PAT PEND
1965 – Early (neck without binding)
Mid 1965 (for a short period of time) Decal runs over two lines the lines are centred
DES 186,826 PAT. 2,741,146 2,817,261 2,972.923 2,960,900
3,143,028 PAT. PEND
Late 1965 – Early 1966
PAT. 2,960,900 2,972.923 3,143,028 2,741,146 DES. 186,826 PAT. PEND
Mid 1966 – Very late 1967
DES. 186,826 PAT. 2,960,900 2,972,923 3,143,028 2,817,261 2,741,146 & PAT PEND
At this point the Entire decal changes with the “Fender” now being black with gold outline.
An “R” in a circle is placed above the “r” in Fender
Late 1967 / Early 1968 – Early 1970s Decal runs over two lines (and is centred)
PAT. 2,960,900 2,972,923 3,143,028 2,741,146
3,236,930 3,260,148 DES. 186,826
