Jazzmaster Vintage '64 Pickups REAL or FAKE
- irv78
Hi guys, I have the opportunity to buy Jazzmaster Pickups from '64 for only 200 Euros. But I'm not sure if they are genuine because I've never seen ones. I've got some photos that the guy sent me. Maybe somebody can tell me if they are genuine.
Pickup 1
Pickup 2 (sorry, I only got this blurry pic)
Do you guys think there's something fishy with these pickups, or do they look fine to you.
Comments are greatly apreciated.
Pickup 1
- Orang Goreng
Re: Jazzmaster Vintage '64 Pickups REAL or FAKE
They look fine to me. I'm a bit puzzled about the stamp, as mine are from December '64 and still have handwriting on them, but it wouldn't be out of the ordinary to have overlapping systems. A yellow stamp on gray pickups was the style for a while, I forget the exact period. The only aftermarket gray ones I know are the Duncan Antiquities, and the only set I've seen in person looks nothing like these or mine.
Here's one of mine for comparison:
- luau
- Admin
http://www.jimshine.com/jazzmaster/intr ... jazzma.htm" onclick="window.open(this.href);return false;1964-1966 The fiber changes to a gray color and dates are applied to the bobbins. First the dates are a small stamp with the Month, day, year and initials of winder. These appear on the end of the black bobbin pickups and overlap to the early grays. Then the dates were penciled in, but by the end of '64 and early '65, we see the typical black marker style of dating
- irv78
You guys are amazing! Thanks a lot.
I guess I'll buy them then.
- irv78
The pickups arrived! Now I have a question ... which pickup is for the neck position and which is for the bridge? One pickup has a small marker dot (see picture)
The other pickup has nothing whatsoever. Maybe somebody can put me in the right direction.
- null.fuzz
If you check the resistance put the higher one in the bridge - I think bridge pickups are typically wound a little more. If they're close it really shouldn't matter.irv78 wrote:The pickups arrived! Now I have a question ... which pickup is for the neck position and which is for the bridge?
So I pretend there aren't ten strings tied to all ten of my fingers.
- irv78
Already tried that ... but my crappy multimeter doesn't give a consistent reading. I might need a better one (it was dirt cheap).
- ohm-men
If my memory serves me correct, then the Black/Yellow wired PU should be the bridge and the Black/White Pu should be the neck pu.
(At least that is the Fender pu wire code.)
- irv78
Hmm ... the wires on both pickups are kind of white.
From what I've learned in this thread viewtopic.php?f=7&t=24863 the pickup with the blue mark is usually the hotter thus meant for the bridge. But to make sure I guess I'm getting a new multimeter.
- sookwinder
this is one of the pups from my vintage partscatser Jag... it is March 64 and has a stampOrang Goreng wrote:They look fine to me. I'm a bit puzzled about the stamp, as mine are from December '64 and still have handwriting on them, but it wouldn't be out of the ordinary to have overlapping systems.
