Thanks for sharing the video. Oxalic acid did pop up in my search - I'm going to give it a try - though I'm going to wait until after I remove the finish so that the finish doesn't act as a mask for the acid.DrQuasar wrote: ↑Wed Dec 15, 2021 12:12 pmMamie Minch on guitar restoration: oxidation chemistry
I remembered this video re: rust removal. I don't know if oxalic acid would work but maybe oxidation is oxidation?
Triple Awful Offset Restoration - Teisco, Stiles, Homemade Weirdo
- will
Re: Triple Awful Offset Restoration - Teisco, Stiles, Homemade Weirdo
- will
I believe it will - I'm going to replace the headstock piece that has worm damage with some wood harvested from a stray Teisco, add some (maple, I think) wood to fill the old truss bar channels, and use a more modern truss rod. The guitar is really ugly now, but most of the damage to the neck is from the glue separating and rust staining. I think once it is glued back together it will look much more trustworthy.
- MattK
I’ve taken rust stains off wood with oxalic acid, it’s effective. One tip is to wipe it off just before you think it’s done, because it keeps going a little!
- Ceylon
Is the Stiles by any chance made in Italy? The body shape, fretboard and neck all look very Galanti Grand Prix but with a different hardware loadout.
Electricity still lingers
- will
- will
After roughing out the ABS cement patches:
And after some polishing, the patch is hard to see and appears to be sticking well:
- MattK
Superb! as always.
- CorporateDisguise
Obligatory, I would just rock it as is post.
I’m really looking forward to seeing what you do with Teisco. That neck is so far gone.
- will
CorporateDisguise wrote: ↑Sat Dec 18, 2021 6:55 amObligatory, I would just rock it as is post.
I heard that Ry Cooder plays a guitar with a neck that’s separated into three pieces. It’s worth extra $$$$. Three times the tone and sustain.
- will
Drafting out a bridge plate for the T-60.
The end is extended a bit to cover the damage from whoever installed the trem as a bridge, and some holes so that I can bend it into shape.
- MattK
- will
- MattK
Nice! If any measurements from my NB-4 are useful, I have a set of Vernier calipers and I know how to use ‘em.
- will
I have an NB-4 over here that I'll be putting the bridge onto - always liked everything about the bass except the bridge (and how it moves all of the strings to one side if I try to adjust the intonation!) I'll post some pictures if it works out.
- will
I picked up a junky Teisco to donate some wood patches to the T-60, and it had the most pre-broken screws I've ever encountered on a guitar
The only screw holding the tailpiece down that wasn't broken was the size of a tuner screw.
