Request for AV65 Jag gutshot pics
Hey all, I would really appreciate it if someone could snap a few quick pics of the volume and tone pots/tone cap and throw them up here. I suspect a guitar I just bought swapped them out, but it's hard to tell for me.
- _chilly_chilton
Re: Request for AV65 Jag gutshot pics
I may be doing some setup work on my AV65 JM this week, and if you'd be interested, id be glad to pull the guard and take some shots of the electronics for you. Someone with more knowledge, correct me if I'm wrong, but I suspect the AV65 jag and JM use the same value/brand 1 meg pots and caps. shoot me a PM in a couple days if you don't find what you're looking for before then!
It would be easier if you snapped some pics of yours.
AV65 jag has p/n 0019066000 pots (1meg audio taper) on lead circuit ...
https://www.fmicassets.com/Damroot/Orig ... A_SISD.pdf
https://darrenriley.com/store/fender-1- ... 019066000/
- tammyw
- sunburster
1MEG CTS pots on the lead circuit, just like in the pics above. The date of manufacture is indicated by the four digits after "AUD". First two digits are the last two of the year, the other two digits indicate the week of the year. In the above pics, it is 1402. This means the second week of 2014. If your pots date to much later than your neck/body dates, they've been swapped.
Thanks a ton guys.
