Stock 65AVRI - neck shimmed?
deluxejazzmaster
Post by deluxejazzmaster » Tue Jun 18, 2019 11:15 am
Hello there- I have a 65 AVRI Jazzmaster and am wanting to have lower action. I have not changed the angle of the neck since purchase and have heard that these were angled when made. (not sure if that is true). I wonder if a little shimming will give it better action.
Any input would be appreciated.
Larry Mal
Re: Stock 65AVRI - neck shimmed?
Post by Larry Mal » Tue Jun 18, 2019 11:56 am
How low is your bridge right now? Can you lower it?
deluxejazzmaster
Post by deluxejazzmaster » Tue Jun 18, 2019 2:00 pm
If I have the thick string side pretty high to cut back on buzz but it ain't holding it's own very well.
Danley
Post by Danley » Tue Jun 18, 2019 2:26 pm
If you need break angle to avoid buzz, you probably have some other issue to address with your bridge; I’d make sure all the height screws are level with their twin, and contact the bridge baseplate firmly; also inspect for any particularly loose saddles (you can add stiffer/longer springs to the high and low e strings in particular to firm them up.) If the rest of your bridge is fine, you don’t need a ton of height or break angle to avoid buzz. I’d just make sure it’s high enough to rock.
But strictly with regard to the action, I wouldn’t fear inserting pocket shims if you feel the need. On guitars with non-angled pockets you often borderline need one to get ‘modern’ string height without lowering the bridge all the way, and I wouldn’t hesitate to shim even an angled pocket if I felt it needed it.
Marc
Post by Marc » Tue Jun 18, 2019 2:43 pm
I’m 99% certain the 65 AVRIs had an angled neck pocket and the earlier 62 model does not. My Firemist Silver 65 JM (it’s a 2012 or 2013 I believe) has a very low action with a Staytrem bridge which was fitted when I bought it. The bridge height is fairly high and I have had no problems with buzzage. I’m thinking that I could raise the action a tiny bit actually - just for personal preference really as there no issues.
andy_tchp
Post by andy_tchp » Tue Jun 18, 2019 2:59 pm
Well firstly is it bridge or fret buzz?
Shimming the neck and adjusting the bridge height will do nothing to address fret buzz caused by uneven fretwork or a poorly/non-adjusted truss rod.
deluxejazzmaster
Post by deluxejazzmaster » Tue Jun 18, 2019 5:15 pm
Thanks for all the input. The guitar might just need a good tune up. It's a 2017.
timtam
Post by timtam » Tue Jun 18, 2019 5:26 pm
First things first. What is the relief (with capo at 1st, fretted at last fret or where the neck joins the body) ? Measured with feeler gauge if possible. What is the measured action at 12th fret and 1st fret ? Do you have a fret rocker ?
Timtam (noun): Iconic Australian multi-layered chocolate biscuit.
