cobascis
Post
by cobascis » Mon Jul 14, 2008 12:00 pm
Markocaster wrote:
yes the shims were there for a reason. They go in the pocket at the back , remove the neck , again and slip em in. Not trying to be a dick but perhaps your in over your head and should take the guitar to a shop for a set up? I know jags can be a bear at first till ya get used to em
good luck
Thanks, I'm going to work on it til' I get it right, and if I don't, then I get a set up
Regardless, I don't have ANY dough.
1966 Fender Jaguar / 1966 Fender Coronado / 1966 Teisco ET-312 / 1977 Takamine 370S
Markocaster
Post
by Markocaster » Mon Jul 14, 2008 12:14 pm
cobascis wrote:
good luck
I hear ya , I spent mine on a CAR Jag too
If you google guitar shims you should get some info , good luck
cobascis
Post
by cobascis » Mon Jul 14, 2008 12:45 pm
Thanks man, I just made some outta paper, and it works fine. If I push it it creaks to one side, but I won't be doing that in normal circumstances. I'm working on the action, and saving for a mustang bridge ($0 so far
cobascis
Post
by cobascis » Mon Jul 14, 2008 3:23 pm
dug
Post
by dug » Mon Jul 14, 2008 4:53 pm
Did you get the neck on tight?
cobascis
Post
by cobascis » Mon Jul 14, 2008 5:17 pm
Yes, screws are tight
I need to have a bigger shim.
Markocaster
Post
by Markocaster » Mon Jul 14, 2008 10:45 pm
Man just be carefull,
cracks probably not a big deal , does it look cracked inside the pocket?
if the shims worked before then they should still work , how are they in there??
cobascis
Post
by cobascis » Tue Jul 15, 2008 7:46 am
There's a 60 day warranty on it from the store, I'm going to take it in. What should I tell them to do?
Loomer
Post
by Loomer » Tue Jul 15, 2008 9:29 am
Well, I feel it's pretty evident that it suffered a traumatic fall. Does it actually "creak", as in make a noise? Cuz if that's the case, return it, man.
cobascis
Post
by cobascis » Tue Jul 15, 2008 9:31 am
It didn't creak when I got it. Also, I just sold my only guitar for it, and I'm keen on keeping it.
Markocaster
Post
by Markocaster » Tue Jul 15, 2008 1:13 pm
put it back together as well as you can, take it back and inquire about the creaking, if they are a reputable shop they should at least take a look at it and see if they can fix it (dont tell em you took it to bits) or offer a refund. If you have to get your $ back dont worry there are others out there. I just got a CIJ for $500 in fantastic shape, keep looking. or at least get them to do a decent set up if its not cracked. Mark
