Mid-2012 Squier Vintage Modified Jazzmaster Jaguar Mustang
- backporchmusic
Re: Mid-2012 Squier Vintage Modified Jazzmaster Jaguar Musta
Plug is plastic. No idea about what the skunk stripe is there, when the JMJM is without one.
- rhythmjones
Sorry, my brain was on JMs. Sorry.MKR wrote:don't think that's entirely true. i think lots of the wires run through tunnels in the wood (cavities not completely open).rhythmjones wrote:You can remove the entire electronics harness intact. The only solder joint you'll have to undo would be the bridge ground wire.
not my pic, but do you see what i mean? Your esentially desoldering every little section in the cavities That's a lot of taking apart and putting together.
unless of course i am wrong and it's easy like you say. like i said, i'm not good with electronics.
- Mitch
- furrman
Between the Mustang bridge and the BT Jazzmaster bridge, which would be the better choice for the VM Jag? Any other thing to upgrade for better stability? Nut perhaps? Thanks!
- caliban
Nut on my VM Mustang was not good (replaced it with a TUSQ nut), and bridge was meh (replaced it with a mij-mustang-bridge on which I tried to correct the radius-mismatch myself, but a staytrem bridge would probably be better). Vibrato unit was pretty terrible too (replaced it with a 60's one, which can be found pretty cheap on ebay).
Pickups are pretty low-output, but fine, replaced them with MIJ's, but no big difference (as far as I can remember)
By the way the tremolo unit on the Jaguar should be fine (trem arm on the Squiers stays in way better then on the US and MIJ versions as far as I can tell).
- Spitfire7
There's only one who makes the best vintage tortoise shell pickguards. Spitfire Tort.
http://spitfiretortoiseshellpickguards.wordpress.com/
- unreal77
Where you got that block inlay neck?
- Spitfire7
I made it for $15. Its a secret.unreal77 wrote:Where you got that block inlay neck?
Okay, thread can be found here on how I did it.
http://www.offsetguitars.com/forums/vie ... &start=150" onclick="window.open(this.href);return false;
- unreal77
How's the "binding" holding up? I just bought the tape to do it.
Thank HNB and you for the inspiration.
- Spitfire7
Perfectly. I have had it on my strat for over 5 years now.unreal77 wrote:How's the "binding" holding up? I just bought the tape to do it.
- unreal77
That's great news. This weekend my Jag gets the matching headstock treatment and then the faux binding.
- milkybar
Spitfire, those matching headstocks on Squiers! You're turning the Squier world upside-down.
- Spitfire7
Just like it should be lol. I didn't paint them just so you know. I got the Jag painted by HNB and the JM was already like that when I received it. I do claim the tort though, now thats mine.milkybar wrote:Spitfire, those matching headstocks on Squiers! You're turning the Squier world upside-down.
- milkybar
It's a nice tort! Very fire-y. Matching headstocks should really be on every Jag/JM, nice guitars!Spitfire7 wrote:
- rhythmjones
- CROSS_guitars
Only mods I've done to mine is EYguitar mint pickguard and EYguitar Mustang bridge.
The EY pickguard is pretty accurate, I only had to redrill 3 of the holes. the sharp bit on the left horn is more rounded off compared to any other models bit still looks fine.
The bridge, I used blu-tac in the post screws to stop them from retracting from vibration. I also wrapped tape around the poles to reduce movement when the tremolo is being used.
