Hi guys, I have a Ryan Jarman signature Squier, which is a super nice guitar. However, I cannot get on board with the adjustomatic bridge, as I find it irritating when I am playing. Is there a drop in replacement Mustang bridge? I have a feeling that posts, bushings, thimbles or something like that will be different!
Any advice or help would be fantastic!
Adjustomatic to Mustang bridge - advice required!
- Jan Deal
Seas, Starry : Fuzz / Pop / Noises
"Gorgeous, soaring waves of guitars which feedback and squall deliriously with fluid and organic rhythms”
www.seasstarry.bandcamp.com
Re: Adjustomatic to Mustang bridge - advice required!
Well definitely the thimbles/bushings will be different because the AOM has screw-in posts and the Mustang bridge posts just sit in their thimbles.
Measure the inter-hole distance, and confirm that the Mustang bridge you're considering has the same thimble-to-thimble spacing.
To measure the hole diameter you need to remove the AOM bushings. There are several techniques for removing AOM/TOM-style bushings, eg ...
https://www.youtube.com/watch?v=ykWHdRypMUM
https://www.youtube.com/watch?v=Q1ppKxEIF1M
The Mustang thimble holes may not be the same diameter as AOM. More people go the other way, ie to AOM/TOM bridge - this page regarding that transfer suggests that the AOM / modern TOM-style bushing holes may be larger diameter than the Mustang ... which would make your transfer more problematic ...
https://www.jag-stang.com/guitars/the-t ... ic-bridge/
- mynameisjonas
- Admin
Staytrem has a drop-in replacement, or check out this thread if you want to make your own from a mustang bridge you already have lying around.
Edit: I noticed the Staytrem bridge is no longer in production, sorry.
- Jan Deal
Thanks for that, I will have a read of the thread.mynameisjonas wrote: ↑Mon Aug 20, 2018 2:11 amStaytrem has a drop-in replacement, or check out this thread if you want to make your own from a mustang bridge you already have lying around.
- 601210
Apparently they're just backordered until October, but it's not discontinued or anything. Honestly I'd wait for that one if you can, it's easily the best option for me.mynameisjonas wrote: ↑Mon Aug 20, 2018 2:11 amStaytrem has a drop-in replacement, or check out this thread if you want to make your own from a mustang bridge you already have lying around.
I hope they stick with this and beef up production a bit since they're the only company that does an actual rocking bridge AOM conversion, I understand it's a niche but if they're backed up all the time it means they're selling well, right?
- Unicorn Warrior
I'd think so. Waiting on them is such a pain
