Stuck: Mustang Arm Screw
- Danley
Good news is I have one - bad news, it’s stuck in the cigar. ‘64 vibrato; corroded, worried about it disintegrating beneath my screwdriver. For now I have it soaking in white lithium grease. Ideas for next steps?
Re: Stuck: Mustang Arm Screw
Heat (heat gun or small butane gas torch) and penetrating lubricant.
Repeat as necessary for as long as you retain patience or it starts shifting :/
- CorporateDisguise
Yeah, this is what penetrating lubricant is made for. I've always had best luck with PB Blaster. It doesn't take much, but it may take repeated applications. I tend to let it work over night, and come back to it. It really gives it a chance to get through some of the corrosion.
