3-way series selector
jorri
Post by jorri » Fri Jul 05, 2019 7:39 am
Would this work? I have a 3 pickup warmoth JM.
Thinking i will try allowing two series switches: N-M and N-B.
So i have 3 2-way and one 3-way all slide switches, using the 2-way as bridge, middle, N-B series...
... Then the 3-way is a combined series into the middle, parallel or off for the neck.
12
34
56
78
1=neck hot
2=unused
3=mid ground
4=neck hot
5=ground
6=out
7=mid ground
8=unused
So basically a standard series switch, but the last two pins cut the neck going to output, and retain the middle ground connection.
Probably would work on a mustang with phase on the other switch or something. Thanks.
jorri
Re: 3-way series selector
Post by jorri » Fri Jul 05, 2019 7:44 am
Does it matter which pickup comes first in series? Does 3 pickups in series suck? I basically like seriesNM+parallel bridge a LOT which i use currently.
