Nahh, that's probably fine. Mine moves about that much on my main JM and stays in tune perfectly.Pelicashka wrote: ↑Sun Sep 24, 2023 1:08 amI think this is too much movement
https://youtube.com/shorts/1IiyAQWBwbY? ... FWH6pehRgA
Mastery Bridge- Some movement?
Re: Mastery Bridge- Some movement?
- Pelicashka
So, what should I do in this case? Should I just ask the luthier to take care of the tuning stability issues without replacing the thimbles?JSett wrote: ↑Sun Sep 24, 2023 1:55 amNahh, that's probably fine. Mine moves about that much on my main JM and stays in tune perfectly.Pelicashka wrote: ↑Sun Sep 24, 2023 1:08 amI think this is too much movement
I am kind of confused because some people are saying that their Mastery bridges don't move at all, and others say that they have some movement like you do.
I've had some that move a little and some that don't. Fender thimbles aren't made to as tight a tolerances as Mastery's own so they will vary somewhat.Pelicashka wrote: ↑Sun Sep 24, 2023 2:07 amSo, what should I do in this case? Should I just ask the luthier to take care of the tuning stability issues without replacing the thimbles?JSett wrote: ↑Sun Sep 24, 2023 1:55 amNahh, that's probably fine. Mine moves about that much on my main JM and stays in tune perfectly.Pelicashka wrote: ↑Sun Sep 24, 2023 1:08 amI think this is too much movement
That amount of movement wont be throwing you enough out of tune to be noticeable during the course of a few songs. The problem is almost certainly the nut. It's almost always the nut. Can't hurt to get him to put the correct thimbles in anyway. But you can also do that yourself very easily in just a few minutes if you have a soldering iron.
All of this. The only time it's not the nut is the unusual occasion where the vibrato plate itself gets hung up on the edge of the vibrato cavity/route due to misalignment or too tight a route.JSett wrote: ↑Sun Sep 24, 2023 2:11 amThat amount of movement wont be throwing you enough out of tune to be noticeable during the course of a few songs. The problem is almost certainly the nut. It's almost always the nut. Can't hurt to get him to put the correct thimbles in anyway. But you can also do that yourself very easily in just a few minutes if you have a soldering iron.
- Pelicashka
Thanks, guys. Going to pay a visit to the luthier tomorrow.
