Hello!
I plan to build my own Jaguar based on the Fender Jaguar.
I have a question about electronic scheme. In general I plan to use all features of the Jaguar's scheme but also want to add modification - 3rd mode when pickups switch to the parallel mode like Fender Hybrid guitars, with using push-pull pot.
Could you help me modify standard scheme to implement this modification?
Thanks.
Jaguar - pickups in the parallel mode
- babich
- MayTheFuzzBeWithYou
Re: Jaguar - pickups in the parallel mode
Hello Babich!
If I‘m not totally nuts or still too tired right now... the normal wiring already gives you both pickups in parallel mode! (Edit for typo)
Nevertheless: someone here made a mod some time ago that could be what you‘re looking for and probably more (both pickups switchable to rhythm circuit)!
Here is the thread: http://www.offsetguitars.com/forums/vie ... hp?t=50626
Good luck!
Good luck!
