New Fender Vibrato?
ChrisDesign
New Fender Vibrato?
Post by ChrisDesign » Fri Mar 27, 2020 4:40 pm
I have a 2017 Jazzmaster Standard, made in Mexico with the cheap vibrato. I’ve already upgraded the bridge to a Staytrem and have never looked back. But if there any advantage to upgrading the vibrato to an American model?
adamrobertt
Re: New Fender Vibrato?
Post by adamrobertt » Sat Mar 28, 2020 7:01 am
If you search these forums you'll probably find about 104853752495426936 posts about this, I reckon. Short answer: yes.
parry
Post by parry » Sat Mar 28, 2020 8:31 am
If you use the trem quite a lot, then yes. A little improvement. Mostly in the feel of the arm and the arm's travel. Some people prefer the feel of the spring on American trems as compared to the stiffer MIM springs. The trem arms on the American units pop in and are tension-fit - as opposed to being screwed in - so you might experience issues with the arm not staying put. As mentioned, there are a bajillion threads on that subject as well.
If you don't use the trem (a lot of people don't) and don't intend on it - I wouldn't bother..
Larry Mal
Post by Larry Mal » Sat Mar 28, 2020 8:36 am
I rarely use the vibrato on my guitars but still upgraded the unit on my MIJ Jazzmaster, mainly though because I bought a Mastery unit for my AVRI and switched the AVRI unit to my MIJ.
I would consider the AVRI unit or the American Pro if that is different to be the base level I would accept.
seawalker
Post by seawalker » Sat Mar 28, 2020 10:41 am
I made the same switch a few years back. The AVRI part is much thicker and heavier duty, and seemed to be a higher quality part. It was a direct swap, too, which was nice. I felt the action was smoother than before. Tonal differences, if there were any I couldn't tell. I guess if you think it's better then in some ways it is better.
You can probably find a used one somewhere, from someone who swapped for the Mastery part.
Maggieo
Post by Maggieo » Sat Mar 28, 2020 12:42 pm
Yo, hit me up.
