Re: some more high e trouble
my high e gets out of tune really easily and breaks after a very short time. I tried to replace it but failed 4 times in a row because the new ones just break at the peghead as I tune it up (I won't even get past B), the ball end however is always fine.
what could be the problem, are the edges of the peghead too sharp for 0.10's?
- Puke+Cry
This happens with me, put the trem lock on and it will be fine.
that's not where it happens, and besides, my trem lock does not function anymore, it's always 'unlocked'. This is how Vinkie set it up for me to increase tuning stability (and it works great). I don't think the bridge or tremolo have anything to do with it.Puke+Cry wrote: This happens with me, put the trem lock on and it will be fine.
edit: however, a few days ago something went wrong when I was using the tremolo quite heavily, the tremolo made a terrible noise, the whole thing went out of tune and the bridge and tremolo had gone down quite a bit. I fixed the bridge but the trem bar is still lower than it used to be. I guess the 'e-problem' started then.
after all the trouble I've been through getting this thing to work properly and staying stable I'm starting to think I'd be better off selling it and saving for an AVRI.
- Puke+Cry
Yes, I think this is a problem which happens with all CIJ's when the trem is used a lot, i think its due to the spring being weak and poorly cut leaveys . I'm getting the USA trem soon
- i love sharin foo
Try tightening the screw in the middle of the trem plate. That should fix that problem.Sauerkraut wrote: I fixed the bridge but the trem bar is still lower than it used to be. I guess the 'e-problem' started then.
As for the string breaking, it sounds like the problem may be at the tuner shaft or the nut. Is it breaking right at the tuner? If it is, take a real close look at the edges of the shaft, where the notch is cut. It may have a sharp edge right there.
Justin
Last edited by i love sharin foo on Fri Apr 06, 2007 6:36 pm, edited 1 time in total.
A death’s head ring upon his finger
- Pumpkin
If its breakin near the tuners, having an AV wont solve anything as they all use the same tuners.Sauerkraut wrote: think I'd be better off selling it and saving for an AVRI.
Do what justin said, check the string tree too....use a magnifying glass.
- Mad-Mike
I do know for a fact that the CIJ trem spring tends to give a little easier over time if you use the trem a lot, I just tighten the spring, it does not use up that much range. I figure when I replace it I'll just replace the spring.
One thing's for sure, even the CIJ floating trems are tough mofos. I use this thing for stuff most people need a Floyd Rose and a locking nut to do, and yet I have only that one little spring to worry about, that's pretty good, if it were a floyd I would have had plenty more problems to keep me busy, that's why the Jag always get's played and I only touch the Kramers once in awhile.
It's Me
I think it's breaking right were I it there's a bend and it gets out of the tuner, so I think it has to be a sharp edge.i love sharin foo wrote:Try tightening the screw in the middle of the trem plate. That should fix that problem.Sauerkraut wrote: I fixed the bridge but the trem bar is still lower than it used to be. I guess the 'e-problem' started then.
Justin
Thanks for your help.
Vinkie figured the spring was a bit weak, but it didn't have to be a problem, I guess I'm such an abusive user I just have to replace it.
thanks to all of you for your help. There wasn't much of a problem in the end; I just didn't take enough string, cut it off too short so it only went around the peghead twice, apparently that's not enough.
I have to buy a new feather for the tremolo, it still works but the trem arm is quite low. What still bothers me is that I don't know what caused the bridge to dig itself in, guess I can only hope it won't happen again.
- Vinkie
Just use the spring adjusting screw to tighten the spring some more and I'd expect everything to be ok again, maybe you don't need to replace the spring yet.Sauerkraut wrote: thanks to all of you for your help. There wasn't much of a problem in the end; I just didn't take enough string, cut it off too short so it only went around the peghead twice, apparently that's not enough.
- i love sharin foo
Yeah, that is a sound suggestion. In my experience, the stock srings are pretty good. I don't use real heavy strings though (usually .010-.052).Vinkie wrote: Just use the spring adjusting screw to tighten the spring some more and I'd expect everything to be ok again, maybe you don't need to replace the spring yet.
Justin
I use 0.10-0.52's aswell, and by 'feather' I ment spring to avoid confusion, it's a little language-mixup. I'll just tighten the spring again. Guess I got all uptight for nothing again.i love sharin foo wrote:Yeah, that is a sound suggestion. In my experience, the stock srings are pretty good. I don't use real heavy strings though (usually .010-.052).Vinkie wrote: Just use the spring adjusting screw to tighten the spring some more and I'd expect everything to be ok again, maybe you don't need to replace the spring yet.
Justin
- Vinkie
Good Luck Sauerkraut
The trem setup I used before on your guitar can be readjusted by turning the tension screw until the trem plate will just about hit the covering plate with the string in tune. Like this you'll get only detuning action but with a firm feeling and a higher trem arm. As the strings will go up in pitch as you add more spring tension you'll have to probably retune and retension a few times before you'll find the right balance.
