Johnny marr jaguar mod wiring diagram
- Markocaster
Got a plate and a tele 4 way switch , who has a link or pic of the wiring diagram?
I have tried searching here but not found much. Cheers. Mark
- In-Sound
Re: Johnny marr jaguar mod wiring diagram
presumably it would function as B, B+N, N, BxN as is common to 4-way tele switches. You could just look for a tele diagram. Wire the switch that way; the rest should be identical to a standard jag (unless i've got my info all wrong)
- Brock the Mod
^This is pretty dead on.In-Sound wrote:presumably it would function as B, B+N, N, BxN as is common to 4-way tele switches. You could just look for a tele diagram. Wire the switch that way; the rest should be identical to a standard jag (unless i've got my info all wrong)
The real question is how his rhythm circuit works, as I read in an interview it doesn't work like a standard one.
- Markocaster
Cool thanks and yea I read that interview about the rhythm circuitBrock the Mod wrote:^This is pretty dead on.In-Sound wrote:presumably it would function as B, B+N, N, BxN as is common to 4-way tele switches. You could just look for a tele diagram. Wire the switch that way; the rest should be identical to a standard jag (unless i've got my info all wrong)
Just leaving mine as is
- Brock the Mod
I'm debating whether to just do a JM style toggle or the 4 way switch in my Jag build. Finding the plate would be the most difficult part.Markocaster wrote:Cool thanks and yea I read that interview about the rhythm circuitBrock the Mod wrote:^This is pretty dead on.In-Sound wrote:presumably it would function as B, B+N, N, BxN as is common to 4-way tele switches. You could just look for a tele diagram. Wire the switch that way; the rest should be identical to a standard jag (unless i've got my info all wrong)
- theworkoffire
Diagram is in the library: http://www.offsetguitars.com/forums/vie ... 29&t=41339
You can adapt the 4-position Tele JM one for the Jag.
- Markocaster
Thanks Bentheworkoffire wrote:Diagram is in the library: http://www.offsetguitars.com/forums/vie ... 29&t=41339
- saxjag
Unless you contact stereordinary, who is currently taking orders for Round 3 of his custom plates.Brock the Mod wrote:Finding the plate would be the most difficult part.
- Brock the Mod
Yeah Paul makes them but hes a source on here. Its hard to find them otherwise.saxjag wrote:Unless you contact stereordinary, who is currently taking orders for Round 3 of his custom plates.Brock the Mod wrote:Finding the plate would be the most difficult part.
Isn't a 4 way tele switch to big to fit in the Jaguar body cavity without rerouting?
BTW in the guitar world magazine (or whatever it was) he said his rythm circuit is now the bass cut switch.
- Brock the Mod
Nifty.Azzmaster wrote:Isn't a 4 way tele switch to big to fit in the Jaguar body cavity without rerouting?
- tdbajus
Anyone have the full schematic? I'm surprised at how useful his various hi pass filters thingies are.
I've installed two Lollar Jag pickups in a project Jazzmaster, and it's killer. Sounds very, very similar- I'm surprised the scale length doesn't seem to be as much of a factor in the tone as I thought it would be. If you find the 24" scale to be a little rough for your sausage fingers above the 14th fret like I do, this is pretty damned wonderful.
[edit]
No sooner do I post than I find it online.
http://www.databasesonline.com/guitar/J ... Manual.pdf" onclick="window.open(this.href);return false;
[edit]
