that's what it does now, apart from lacking a killswitch. And I think that it might be fine after hearing both of your thoughts.Shadoweclipse13 wrote: ↑Wed Feb 13, 2019 7:44 pmI don't know for sure as I've never messed with stereo setups, but I don't see why you couldn't have 1 3-way toggle for each output (B/B+N/N). If I had a stereo guitar, I would have the pickups each run to both switches, both switches wired as a 3-way (B/B+N/N), and I'd just have an on/off or killswitch for one of the output jacks.
The thing I really want is to be able to suddenly whack on a different different amp in the middle of a track, but I guess by having each toggle as a panpot I'd be limiting myself more than by just having a kill switch- ie when using one of the amps in a two amp setup, I'd only be able to have both pickups going to that amp rather than one or the other.
Current setup plus volume pedal it is I think then. Thanks dudes!
