Left handed Jazzmaster from parts
- Acoasma
Re: Left handed Jazzmaster from parts
The first big problem.
As a novice with zero experiences I had planned to give the body to profesionalist's hands for adjusting neck pocket,because the neck doesn't fit. After returning from the veterinary I smoked couple of joints and had understood that give up adjusting your neck pocket is for motherfuckers.
So I get 320 sanding paper, straigtht piece of wood and started to sand. (and actually started destroying not cheap body)
Everything had to been fine, until I realised it's too much.
Down side is ok.
But on the upper side I had to sand circa 1mm more(like a finger nail hole).
Important thing is that the hole isn't going at the bottom of the heel (is the "heel" correct word?). I just pushed too much on the upper side of sander. Here is photo:
So, what next??? Should I have to continue or obtain wider neck, or fil the gap with the glue and tiny wood sticks and resand? Please, give me an advice. Thank you.
Down side is ok.
- Acoasma
- JVG
The perils of sanding stoned!
I would wait until you have the neck properly attached (and strings on the guitar) until you worry about filling the gap. At that time you can make some thin wedges of wood to glue into the slot.
J.
J.
nice work here - can't wait to see the finished guitar. left on!!
- Acoasma
Dekuju aob! Thank you!
Just waitin for pickups and bridge.
I decided to buy hosco tremolo, coz I found one really cheap and it really looks like the fender japaneese one... I also wired the pickguard, but there's still some bugs and I am still waitin for 33 cap. There no quality 33 caps aroud here. 22, 01, 47.... Yes. 33? No. Weird. But over all, with vintage style bridge the guitar plays and stay in tune. There s some problem with octaves but I will solve this problem after final bridge instalation and proper neck adjustment.
Question
Ho estly with bridge I could buy?
I want staytren but there some original fender one, very near to me for almost half price and it the same seller where I will have to buy pickups. So is the really really really big differences between the fender and staytrem?
Question
- Acoasma
- MrFingers
They are wired mirrored. The left lug becomes the right lug, and vice-versa.
- Acoasma
- Acoasma
Guitar is almost finished.
<a href="https://ibb.co/gSgeU8"><img src="https://preview.ibb.co/bvtF2T/153139243 ... 253027.jpg" alt="1531392434479_1306253027" border="0"></a>
<a href="https://ibb.co/mqqbbo"><img src="https://preview.ibb.co/nFhB98/153139263 ... 619574.jpg" alt="15313926345941975619574" border="0"></a>
