Olympic White Jazzmaster Project Done Pg. 3!
- Danley
Re: Olympic White Jazzmaster Project
Really curious to get your opinion on the Picassos when it's all done; I have a bridge model wound 10k with de-gaussed A5 (his opinion, the best match to a WRHB,) and it is very bright and low output. Yours should be stronger with the full-strength A5 and greater amt. of winds. Not that a lot of people don't want that or buy these for that low output/bright tone in the first place, but it's funny - A vintage-wound Jaguar or Jazzmaser single in the neck decimates mine in the bridge volume-wise. Good call on getting a set there, just in case. They're def. quality though.
- HNB
I tend to go for high ceramic humbuckers, but I do like JB's and those are alnico 5 so I figured it might sound similar or at least have some oomf. I got a more traditional set of his pickups that were great, but the output was too low/quiet for my tastes.
Christopher
Lilith Guitars
Lilith Guitars
- Danley
I actually have two other Rose sets - Two Buff Beauties in a Mustang (almost perfect - higher output but very clear,) and three Strat Mariposas (need to find a Strat for them, but last time I had them installed I loved them - just right as far as output and tone balance.) The Picasso is my outlier, still trying to figure out how I really want to use it.
- HNB
Cream or white plastic? I am leaning towards white.
2019-08-12_10-04-44 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
Both look good to me, but I'd probably go with the white.
- Amon 7.L
Extra vote for white.
That body looks awesome, MJT makes really great finishes.
- HNB
- HNB
Did some work on it today. I drilled the bridge thimble posts bigger to fit the thimbles and installed the ground wire. I squared off the tremolo hole for the tremolo and marked where the screws need to be drilled to mount it. Need to order tremolo mounting screws and shielding paint. The Allparts neck fits with no sanding needed. I also worked on sanding the shine off of the mind guard and adding some goop to the white knobs to dirty them a bit. Added the strap buttons.
20190813_124802 by Christopher Louck, on Flickr
20190813_125755 by Christopher Louck, on Flickr
20190813_133901 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- HNB
Got a coat of shielding down. Also tremolo is mounted. I also did the pickguard shielding and wiring today.
20190817_140119 by Christopher Louck, on Flickr
20190817_141812 by Christopher Louck, on Flickr
20190817_140024_HDR by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
That looks great. And man, that shielding paint is friggin' DARK!
- HNB
Installed the Gotoh Kluson looking tuners and a bone nut. Just waiting on pickup covers and the shielding paint to dry.
20190819_092626 by Christopher Louck, on Flickr
20190819_092609 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- Pacreamer
Really nice work on the neck. Looks great!
- HNB
- HNB
Progress! I wasn't having luck getting white Picasso pickup covers so I just ordered some normal white Jazzy ones instead. I put foam between the pole pieces so the holes in the cover would be blocked. I also put foam in the cover on the left and right to help keep the pickup from shifting left or right. Once that was done, I got the pickguard and pickups screwed down fine. Sadly when I went to mount my neck I realized I didn't have any strings to align it. I will just have to totally finish it once I get more strings. It is looking good with the white though!
20190904_073811 by Christopher Louck, on Flickr
20190904_073816 by Christopher Louck, on Flickr
20190904_182249_HDR by Christopher Louck, on Flickr
20190904_182618_HDR by Christopher Louck, on Flickr
20190904_190526 by Christopher Louck, on Flickr
20190904_190542 by Christopher Louck, on Flickr
20190904_190535 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- Rgand
I like the way you made the JM covers work with your pickups. Nice looking guitar, there.
