New Jazzmaster build
robinbowes
Re: New Jazzmaster build
Post by robinbowes » Mon Jul 08, 2019 2:37 pm
I'm thinking I'll get a Fender AV trem with a Staytrem collet and arm, and a regular Jazzmaster bridge with Graphtech saddles.
Any better suggestions?
R.
andy_tchp
Post by andy_tchp » Mon Jul 08, 2019 2:52 pm
Good plan. But don't use the Graphtech saddles.
robinbowes
Post by robinbowes » Mon Jul 08, 2019 3:03 pm
Why? I'm quite a fan of Graphtech stuff - I have their saddles on a Strat, a Tele, and a Pacifica 311MS.
R.
robinbowes
Post by robinbowes » Tue Jul 09, 2019 1:43 pm
Latest mock-up from the guy doing the body + neck:
This is a cream pickguard and Gotoh bridge.
Still torn between parchment/cream and mint green.
R.
valley_parade
Post by valley_parade » Wed Jul 10, 2019 1:21 pm
Parchment looks pretty good to me.
robinbowes
Post by robinbowes » Fri Jul 19, 2019 5:18 am
I'm looking for a Trem unit.
I'm following the part nos. in this document: https://www.fmicassets.com/Damroot/Orig ... A_SISD.pdf
The trem assembly is listed as part no. 0054466000
When I search, I find the AVRI trem is part no. 0054466049.
Are these different units?
Thanks,
R.
alexpigment
Post by alexpigment » Fri Jul 19, 2019 7:08 am
R.
I don't want to speak for him, but I suspect it's related to grounding. If I recall, the graphtech saddles prevent the strings from being grounded at the bridge. You can ground the trem plate instead and it'll probably work fine, but it's not as solid of a connection to the strings.
EDIT: Apparently they also cause an unwanted loss of frequencies, although if you already use them on your other guitars, this may not be a big deal to you:
http://www.offsetguitars.com/forums/vie ... hp?t=62689
alexpigment
Post by alexpigment » Fri Jul 19, 2019 7:19 am
Thanks,
R.
https://darrenriley.com/store/fender-am ... 054466000/
If you look at the description on Darren's site, he mentions that the two part numbers are the same. Not sure why the number changed - maybe they tweaked some small aspect of it.
robinbowes
Post by robinbowes » Fri Jul 19, 2019 7:26 am
Yeah, I'm aware of that and no, it's not a big deal. My Strat sounds stratty, my Tele and 311MS are still spikey on the bridge pickup.
I'll be getting a good quality bridge with metal saddles and replacing with the Graphtech so I will be able to compare/contrast.
R.
robinbowes
Post by robinbowes » Fri Jul 19, 2019 7:27 am
Cool, that's good to know.
Maybe I'll have to put an order in with Darren as the AVRI Trem is not easy to get here in the UK.
Cheers,
R.
robinbowes
Post by robinbowes » Fri Aug 16, 2019 8:30 am
I have change of a Gold anodized pickguard, complete with wiring loom.
Anyone got any pics of gold on gold to help me decide if it will work?
Thanks!
R.
robinbowes
Post by robinbowes » Wed Aug 21, 2019 2:19 pm
Got some different knobs to fit in with the gold theme:
I believe they are known as "tea cup" knobs, from Hohner guitars.
I shall see how they look on the Jazzmaster.
R.
Fendereedo
Post by Fendereedo » Sat Aug 24, 2019 3:16 pm
R.
How did these look? I saw some on eBay recently, and was intrigued by them, but the mock up image the seller put up, made them look like they didn't cover over the nut.
robinbowes
Post by robinbowes » Sat Aug 24, 2019 3:18 pm
I don't know - I've not got the body yet!
R.
Fendereedo
Post by Fendereedo » Sat Aug 24, 2019 3:31 pm
R.
Ah, ok. Look forward to seeing the results.
