Bobber - A Bit Different
- Rgand
On the 'What's on your workbench' thread, I posted a proposed pic of what I'm calling the Bobber. It's started as a Telerauder body I was making for another forum member that got goofed up string through holes and had to make a new one for him. This one was just lying around and I didn't want it to go to waste. There are some things I've been wanting to try so this will be the test bed. Here's the concept image although some of the things will change on it. The controls, for instance will not be as shown. There will be other changes as I go along, too. The color will probably be nothing like this but that still is up in the air. The pickguard shape is Maverick inspired.
The body after modification to the heel and upper horn.
Yesterday I installed threaded inserts in the neck.
Then I bolted the neck on to make sure it fit. Notice it's already different than the projected image because it has a rosewood fretboard..
Here's the neck before I shaped the headstock. Warmoth lets you order an in-line paddlehead for custom headstock designs. I have shaped this one like the one on the roadhouse. Pretty much like the headstock on the concept image. The neck is a Gibson scale conversion.
It'll be fun to see where this goes. I have some shoulder surgery coming up in a few weeks and having one arm in a sling will certainly stall things for a time. Until then, I'll continue working on this one. I have to plug and re-do the bridge and string through holes before I can mount the bridge on it. At this time I'm planning a humbucker Tele bridge (you can see one in the photo with the neck bolted on.)
- BTL
Re: Bobber - A Bit Different
This looks like a fun project...looking forward to it!
Owner, Lowe Custom Guitars
- Rgand
Dig it! You should've left the paddle headstock uncut and just clearcoat it as is It would work well I think.
- Rgand
Thanks.Shadoweclipse13 wrote: ↑Mon Jul 29, 2019 8:55 pmDig it! You should've left the paddle headstock uncut and just clearcoat it as is It would work well I think.
LOL, I was tempted to do just that but It would need a laminated butcher block body for that. And a beveled edge.
- Amon 7.L
It would be the perfect AXE, literally: the butcher master.Rgand wrote: ↑Tue Jul 30, 2019 5:17 amThanks.Shadoweclipse13 wrote: ↑Mon Jul 29, 2019 8:55 pmDig it! You should've left the paddle headstock uncut and just clearcoat it as is It would work well I think.
Feature, the butcher headstock (imagine a swoop mimicking the blade ).
Jokes aside, yet another cool project you've setting up there. I'm very fond of the geometry of the routes, it's art.
- Rgand
Brass spots on the neck would really finish it off, too. Damn, that's tempting...Amon 7.L wrote: ↑Tue Jul 30, 2019 5:30 amIt would be the perfect AXE, literally: the butcher master.Rgand wrote: ↑Tue Jul 30, 2019 5:17 amThanks.Shadoweclipse13 wrote: ↑Mon Jul 29, 2019 8:55 pmDig it! You should've left the paddle headstock uncut and just clearcoat it as is It would work well I think.
Thanks. The routs have evolved over three different times in an effort to reduce the wiring headaches. I really don't like drilling holes between them if I can avoid it.
- Rgand
My recent fun has been drilling and plugging the bogus holes. I used a standard twist drill to size the holes for dowels on the front. Now I remember why I like Forstner bits. At least this will get paint, not a transparent finish. These holes will be covered with the bridge anyway. The back went a bit better since the dowling was 5/16", the same as the Forstner bit that drilled them in the first place. After everything gets flat sanded, I can locate and drill the holes for the bridge I'll be using.
- VPO
I dig this!
- Rgand
Thanks, VPO. It's a fun project. Hopefully I can get on it some this weekend.
- jvin248
Nice guitar project!
You know, you don't really need to use string through holes. I hate drilling them, the drill tends to wander without half drilling from both sides, and I hate re-stringing guitars with them. I have converted Tele bridges to be top loaders by drilling the bridge plate and that works a lot better for re-stringing over the life of the guitar.
- Rgand
That's a good idea although this is the first time I've had difficulties. My jig was off when I drilled them and that's my fault for not checking it first. I do have a top loader I may use but it isn't what I'd call top quality. The market for top loading Tele humbucker bridges is a little lacking.jvin248 wrote: ↑Fri Aug 02, 2019 4:51 pm.
My favorite humbucker bridge is the Rio Grande Vintage Tallboy Twangbucker but I don't want to invest that for this guitar since I have pickups already. I'm going to try one on a future build.
- Rgand
I did mention that this was not a set-in-stone design, didn't I? Well, with the rosewood fretboard also came cream colored marker spots. Soooo..... a little color change going on at this time. who knows, though? It may morph back again but for now, I chose a cream pickguard (have the material already) which exactly matches the spots. Also, the paint will need to go with the pickguard color.
- Amon 7.L
I like this revision quite a lot, morphing is always an intriguing subject, especially in situation like this!
I'm looking forward to see how the project unfolds.
- Rgand
Thanks, Amon. The color might be different. I'm also toying with something like the 1949 Studebaker Willow Green.
