Guitar Fetish Full Scale Jaguar Build
- gerardguey
Re: The Elusive (Budget) Full Scale Jaguar Build
So there have been some changes to my plan that is stalling my progress with this build, but I think for the better. The whole idea of this being as cheap/economic as possible have gone completely out the window as I got more invested in this project with it being my first jag/jm project.
First, I have decided to order a custom neck. I have larger hands, and like thicker necks with wider nut widths, so after considering my options and pricing I decided to give Tonebomb a try. I have ordered a body from them through ebay before which took a while to ship, but the quality was decent and they had all options I wanted, so I don't mind waiting. It should be arriving in mid-late november.
Next, after looking at the cheap guitar fetish copper finish everyday and analyzing it in different lights, I came to hate it lol. After a while it just felt dull and lifelessly brown, not the faded CAR or Johnny Marr Metallic KO I envisioned.
I bought some Orange Candy and 2K clearcoat from Kustom Kanz and went to work. I enjoy the new shade of red/orange MUCH more now, I just need to sand and polish to make the metallic particles really shine. it's hard to capture but the effect of the old paint underneath with the transparent orange on top is really stunning in person, especially in direct sunlight.
Here you can see the results of my awful hand chiseled routing and extra wood blocks placed for the plates and pickup heights. I already have limited tools and found myself with only a weak drill to work with, so while it isn't pretty inside it does the job. It's a $80 body so I don't feel too bad, and with how much I ended up spending on the neck Im hoping to get a custom Guitar Forms body with a professional finish in the future.
- bodhi
Re: Guitar Fetish Full Scale Jaguar Build
Does anyone know if the GFS body would work with a 24" scale? Looking at the pictures, it's difficult to tell if the bridge position would be on the edge of the swimming pool route or not...
The trem cavity is probably in the JM position?
I'm not too fuzzed about the exact placement of parts, but it looks like a 24" scale jag-ish build could work, with some adjustments to the pickguard.
- GilmourD
It'll definitely work on the original version of the body that needs to be routed to fit a proper Jazzmaster setup. I'm not sure about the revised version.bodhi wrote: ↑Mon Jan 22, 2024 1:32 pmDoes anyone know if the GFS body would work with a 24" scale? Looking at the pictures, it's difficult to tell if the bridge position would be on the edge of the swimming pool route or not...
- gerardguey
I forgot about this thread since I paused the project while I wait for the neck. I dont have the pickguard anymore to double check but here is when I laid out a standard jag pickguard on the stock body:bodhi wrote: ↑Mon Jan 22, 2024 1:32 pmDoes anyone know if the GFS body would work with a 24" scale? Looking at the pictures, it's difficult to tell if the bridge position would be on the edge of the swimming pool route or not...
The problem is the neck pocket placement of a Jag is lower than a JM, that's why there's a gap at the top of the pickguard. So while it looks like theres room for a 24in bridge placement, there may not be. If you want a Jag you're better off buying a Jag body somewhere else.
- GilmourD
Stupid idea here, but it comes from me getting a 3D printer recently...gerardguey wrote: ↑Fri Feb 02, 2024 5:36 pmI forgot about this thread since I paused the project while I wait for the neck. I dont have the pickguard anymore to double check but here is when I laid out a standard jag pickguard on the stock body:bodhi wrote: ↑Mon Jan 22, 2024 1:32 pmDoes anyone know if the GFS body would work with a 24" scale? Looking at the pictures, it's difficult to tell if the bridge position would be on the edge of the swimming pool route or not...
What if we throw the Jaguar pickguard into design software (Illustrator, TinkerCAD, AutoCAD, Fusion 360, whatever) and stretch it along the Y axis (if you're looking at it with the strings vertical) to fit the 25.5" scale but only use that for reference of placement for things since the pickup routes and areas where the plates meet would be stretched, too. Then take the unstretched version and add to the middle to make everything align.
It's easier than my piss-poor explanation there... but if I find myself with some time today or tomorrow I may play with the idea.
My only worry is my print bed maxxes out at 220mmx220mm and I bet this is bigger.
- gerardguey
I don't event think you'd have to stretch the whole thing, just full in the gap at the top so that the shape aligns with the body, and move the bottom of the pickguar and/or bridge posts to the correct spot for a 24in bridge. You could probably do it in photoshop and print a cutout. That's how I mocked up my full scale pickguard design earlier in the thread.
Honestly though, having worked with this body for some time, I should have waited for a custom body. I love how it looks mocked up and i think it will work, but it was a lot more work and trial and error than I expected. The body is also ungodly heavy, though my perception might be skewed from working on only mustangs since I paused this project.
- Daitong II
Good luck with the Tonebomb order. I’ve been waiting nine months for my order. You don’t have a finish on yours so maybe it’ll be much better.
- GilmourD
I was thinking since pickups ideally "read" a certain portion of the string and harmonic content and that portion of the string moves with scale length the pickup should be proportionally placed.gerardguey wrote: ↑Sat Feb 03, 2024 12:29 pmI don't event think you'd have to stretch the whole thing, just full in the gap at the top so that the shape aligns with the body, and move the bottom of the pickguar and/or bridge posts to the correct spot for a 24in bridge. You could probably do it in photoshop and print a cutout. That's how I mocked up my full scale pickguard design earlier in the thread.
Unfinished bodies actually ship super quick if they're already made.Daitong II wrote: ↑Sat Feb 03, 2024 12:43 pmGood luck with the Tonebomb order. I’ve been waiting nine months for my order. You don’t have a finish on yours so maybe it’ll be much better.
- gerardguey
Ah, I did not consider that. Yeah that would require more math than I can handle. I definitely did not do that for this, my MO was fashion over function lol. This is going to be my shoegaze guitar, so harmonics are gonna be all over the place.
Oooofff... What did you order from them? I should have just paid the extra cost for a warmoth or guitarmill neck at this point but I wanted to try out a small builder whos stuff I bought before. I have been super patient with them, but I felt I had to finally send a stern email the other day after the 4th missed completion date from them. My main issue with them is continually giving "two more weeks".Daitong II wrote: ↑Sat Feb 03, 2024 12:43 pmGood luck with the Tonebomb order. I’ve been waiting nine months for my order. You don’t have a finish on yours so maybe it’ll be much better.
If they just told me straight up "hey we need another month because we are backlogged and understaffed" I could work around that and would appreciate the blunt honesty. But I get that they don't want people asking for their money back. I just wish their website lead times were more honest because from what I've seen they've been a lot longer than 12 weeks for a long time.
- Daitong II
I got a Sherwood green nitro tele bound body and tele neck. It’s been getting finished for the last four or five months supposedly. I tried to get it cancelled because of my frustrations at the length of time but they said it was too far along. Supposedly I’ll get an update tomorrow because the finisher was away for a few days. It all sounds like a bullshit “we just, maybe, started finishing this.” Or maybe “an oh shit we probably should start this” kind of answer. We all know that the update, if it comes tomorrow, will be it needs two more weeks for curing or whatever. And then I’ll email them in another month to get a status update.
I’m going through the same thing with Parklane guitars. Seven months for a neck and I emailed them a few days ago and have not heard back.
The only reliable people I’ve dealt with are Musikraft and Bloomdoom. It’s gotten so frustrating to do parts guitars that I think I’m done with it.
- gerardguey
I've never heard of Bloomdoom, I'll have to check them out. But yeah, as some one who does freelance work and deals with clients, I could never imagine pushing deadlines this many times. Obviously they're different businesses, but if I know im already backlogged when I take a gig, I make sure people know how long it's going to take me before I even accept any payment to see if it works for them. Oh well. Back to using in-stock parts for projects.Daitong II wrote: ↑Sun Feb 04, 2024 10:23 amThe only reliable people I’ve dealt with are Musikraft and Bloomdoom. It’s gotten so frustrating to do parts guitars that I think I’m done with it.
It's also nonsense unless you only ever play open/unfretted notes on all strings.gerardguey wrote: ↑Sun Feb 04, 2024 3:59 amAh, I did not consider that. Yeah that would require more math than I can handle. I definitely did not do that for this, my MO was fashion over function lol. This is going to be my shoegaze guitar, so harmonics are gonna be all over the place.
- gerardguey
Well after 8 months of waiting, I FINALLY got my tonebomb custom neck, and with the weather warming, I can get back to this project. I have yet to sand and buff the body in all these months, so my apologies for the lack of progress on that front.
Despite the neck being 22 frets, the rectangular overhang was shorter than what I needed to create the "shortscale illusion" I am going for. In an exasperated and impulsive move, I cut the overhanging fretboard from a cheap donner neck I had lying around that best matched the dark ebony of the neck, and glued it on, sanding it smooth. The added fretboard is slightly browner than the ebony, but after I oil the ebony fretboard and darken the addition with some india ink I think I can blend it pretty well.
Here it is mocked up with the white custom WD pickguard I designed specifically for the JM body, alongside the same guitar with a stock jaguar shaped parchment pickguard (plus some extra strat covers I had lying around).
Now that I added the extra long overhang, I am realizing I may not have even needed a custom pickguard after all, though it would mean that the bridge pickup is slightler farther from the bridge. Overall though, I do like the look of the pickups closer together with the parchment pickguard, and pulls off the "shortscale illusion" much better since its exactly the same proportions as a standard jag. Since the screw holes line up on both pickguards, I'll experiment further once I finish the neck.
Here is a closer look at the fretboard addition and how it covers the gap created by the standard shortscale jaguar parchment pickguard. (It looks alot shabbier in the pictures since that was right after I glued and did the initial sanding)
- GilmourD
Now we get to the fun part!
My OCD would have driven me nuts knowing that the pickups were at different percentages along the string. I'm also a little crazy, so I would have done the math where I would compensate the location of the pickups on the 24" scale to the same relative positions on the 25.5" scale. As long as it's close that works, though. LOLgerardguey wrote: ↑Tue May 07, 2024 10:45 pmNow that I added the extra long overhang, I am realizing I may not have even needed a custom pickguard after all, though it would mean that the bridge pickup is slightler farther from the bridge. Overall though, I do like the look of the pickups closer together with the parchment pickguard, and pulls off the "shortscale illusion" much better since its exactly the same proportions as a standard jag. Since the screw holes line up on both pickguards, I'll experiment further once I finish the neck.
- gerardguey
Yeah, I guess when you're frankensteining a guitar from scratch you have to compromise somewhere lol. It was an initial concern, but then I realized that's what they did on the fender custom shop jaguar IIRC:
And my own OCD as a graphic designer could not handle those proportions and negative space between the pickups lol. Then when you consider other guitars like Teles with neck humbuckers, Hendrix strats with reverse angle bridge pickups, and I feel like the minutia doesn't matter as much, as long as your're okay with the treble and bass response from the position.
Teles are my favorite guitar of all time, but Jaguar's are my favorite fender design, and those proportions are what give it the sleek look that I want to keep as much as possible.
