How to strip paint?
- cpeck
How to strip paint?
I've got a JM body that I want to strip and repaint...is there an easy way to do this?
Band: http://www.kestrels.ca | Record Label: http://www.noyesrecords.com | Solo: http://weneedsecrets.bandcamp.com
- i love sharin foo
Re: How to strip paint?
What kind of finish is it? Stripping lacquer is really easy, but poly takes some more work. A lot more actually. If it is lacquer, I like to use this gel stripper that Walmart sells. It is citrus based and there are no nasty fumes to worry about it.
Justin
Justin
A death’s head ring upon his finger
- cpeck
It's a 90's MIJ body...not sure how to tell what kind of paint it is.i love sharin foo wrote: What kind of finish is it? Stripping lacquer is really easy, but poly takes some more work. A lot more actually. If it is lacquer, I like to use this gel stripper that Walmart sells. It is citrus based and there are no nasty fumes to worry about it.
Justin
- aen
HEAT GUN. it'll take it donw to the wood in under an hour. You just point it at the guitar, wait for the finish to bubble up, stick a scraper under, and rip it off. If you're really tricky, you can squeeze a scraper under the finish and scoot it around behind the heat gun to get huge pieces off. I just did it to a tele, and I got 3/4 of the back side off in one piece, which took about two minutes.
I prefer their older stuff.
- i love sharin foo
If it is original it should be poly. You will probably need to heat up the paint with a heat gun and then scrape and chip it off using a putty knife or something similar. Usually the stripper won't be too effective with the poly. You could still try though.
Good luck!
Justin
Good luck!
Justin
- i love sharin foo
You beat me by 18 seconds you bastard !aen wrote: HEAT GUN. it'll take it donw to the wood in under an hour. You just point it at the guitar, wait for the finish to bubble up, stick a scraper under, and rip it off. If you're really tricky, you can squeeze a scraper under the finish and scoot it around behind the heat gun to get huge pieces off. I just did it to a tele, and I got 3/4 of the back side off in one piece, which took about two minutes.
Justin
- cpeck
Thanks lads.
Now how about getting it refinished? I've heard car places can do this...I just want a single color. Any advice?
- aen
i love sharin foo wrote:You beat me by 18 seconds you bastard !aen wrote: HEAT GUN. it'll take it donw to the wood in under an hour. You just point it at the guitar, wait for the finish to bubble up, stick a scraper under, and rip it off. If you're really tricky, you can squeeze a scraper under the finish and scoot it around behind the heat gun to get huge pieces off. I just did it to a tele, and I got 3/4 of the back side off in one piece, which took about two minutes.
Justin
BWahahahahhahaha! I am like a SHARK!
- pullover
If you want to do it yourself, you can read up on it at the reranch site, or just google "how to paint a guitar." But if you don't want to do it yourself, which I totally understand, then just take it around to a few automotive places. Ask them if they have any guys there that play guitar, because they will be the most interested in doing it. Usually they will work cheaper if your cool, and don't mind waiting for them to do it when they get the time. They can shoot it in a small area and keep it in a booth with a car so they should be pretty cool about it. You should fill and seal the wood yourself before taking it to them.cpeck wrote: Thanks lads.
- JazzBlaster
I stripped my MIJ it was candy apple and it took a few days using stripper. I repainted it using the reranch stuff and am happy with it. (that was about 7 years ago)
