Yamaha SG-3 & SG-2 replicas - SG-2 Finished p15/18
ludobag1
Re: Yamaha SG-3 & SG-2 replica project builds - frets & spra
Post by ludobag1 » Wed Aug 15, 2012 3:37 pm
i read that of all cans of metallic i have use (mostly autocan) if they were not clear coated rapidely the particles beguin to oxyde and tarnish
that s why i have clearcoat my metallic in the few hours after they are spray ,but i haven't try to not clearcoat them immediatly .
maybe there is a window more long but metallic can't be sand , then if you re not clearcoat them fast you can have bugs on ect .... during the drying;
and where it is difficult metallic doesn't like wet clearcoat on them cause it disturb the metallic particle
when you clearcoat them and they are not totally dry, only do light pass no big charge cause the effect will be change and metallic effect is lost
Post by Stereordinary » Wed Aug 15, 2012 8:13 pm
The nitro IBM I have has aluminum in it, says so right on the can.
Save up for your dream guitar.
theworkoffire
Post by theworkoffire » Wed Aug 15, 2012 11:48 pm
Cool, thanks for the tip, Ludo (& Paul). My cans have no info whatsoever. I couldn't see any big change this morning, but I've just given it another dusting and will clear-coat after my breakfast!
ludobag1
Post by ludobag1 » Thu Aug 16, 2012 2:29 pm
teasing ? ;)
we wait ;D
theworkoffire
Post by theworkoffire » Thu Aug 16, 2012 5:35 pm
Teasing indeed!
But...I managed to get three mist coats of clear on today so all is good.
FIREBOT
Post by FIREBOT » Fri Aug 17, 2012 3:14 pm
theworkoffire wrote:
I was going to have just three jag pickups with stock covers and claws, but I'm now leaning towards using Shapeways to make some more accurate covers like this:
The way I've designed these means the claws are still there but they slot inside the covers. Peter pickup wizard has wound me a set of three Jag pickups - Bridge and RWRP middle in Alnico3 (to be wired as a variable humbucker), RWRP neck in Alnico5. Amazingly, I got them for what I thought I would pay for just two. Wizard indeed!
Wow...
any way I could order a set of these off your specs and files? Who is Shapeways?
Thanks!
theworkoffire
Post by theworkoffire » Mon Aug 27, 2012 9:56 am
Thanks!
They're still at the experimental stage - waiting for delivery now so I can check fit and suitability of the material.
Have been on holiday for a week so I couldn't get as much of the spraying done as I'd wanted. Back into the routine of three coats a day now, following a bit of touching-up after the gun spat a chunk of white something out onto the front with the first wet coat of clear. Digging it out resulted in an unfortunate reunion with the primer - I tried drop-filling with a speck of gold but it didn't really blend properly so I re-dusted the whole front with a couple more coats of gold and carried on with the clear.
I'm sanding lightly where needed and scuffing the whole thing with an ultra-fine scouring pad between coats now. Couple more days to do before I'm comfortable leaving it to cure.
frelonvert
Post by frelonvert » Mon Aug 27, 2012 1:18 pm
theworkoffire
Post by theworkoffire » Thu Aug 30, 2012 2:15 am
Well, the pickup covers just arrived from Shapeways, and I think they're going to work fine.
The surface is still a little rough but I'm pretty sure they can be smoothed and re-polished ok.
The pickups are Vintage Vibe Jag P90s, which are taller than straight Jag pickups because of the bar magnets.
PoppaPopp
Post by PoppaPopp » Thu Aug 30, 2012 2:46 am
The covers look very nice!
"...if you can't punkify a Mustang then something ain't right in the world!" (UlricvonCatalyst)
jaycemumford
Post by jaycemumford » Thu Aug 30, 2012 3:42 am
Cool! Are those covers cast or machined?...
Either way you should be able sand through various stages up to about 1500 then polish them.
"Enjoy every Sandwich" - Warren Zevon
theworkoffire
Post by theworkoffire » Thu Aug 30, 2012 3:58 am
jaycemumford wrote:Cool! Are those covers cast or machined?...
They're 3d printed.
jaycemumford
Post by jaycemumford » Thu Aug 30, 2012 4:01 am
They're 3d printed.
Oooo, cool :w00t:
Still i think sand and polish would be the go! Should get a nice shiny finish.
noisepunk
Post by noisepunk » Thu Aug 30, 2012 7:42 am
Wow, those look great- is there enough room for claws in there?
They tried to give me advice, down at the record shop. I said "Sit down boys, this may come as a SHOCK. But alls I listen to, it's all freedom rock."
theworkoffire
Post by theworkoffire » Thu Aug 30, 2012 11:07 pm
noisepunk wrote:Wow, those look great- is there enough room for claws in there?
Not in these ones - because of the bar magnets you can't use the claws properly with these pickups, and they're already shielded all around the coil. I have another version of these drawn up where the claw fits inside for stock Jag pickups, though, which I may well end up using on the SG-3. These covers are 2-3mm wider than the claws.
