Yamaha SG-3 & SG-2 replicas - SG-2 Finished p15/18
theworkoffire
Re: Yamaha SG-3 replica project build
Post by theworkoffire » Tue Feb 15, 2011 5:39 pm
I'm just discussing pickups for this with Curtis Novak.
In the bridge I'm going for two of his 'Narrow Range' pickups (half a WRHB) that will combine to approximate a WRHB when the second one is blended in.
For the neck, I've asked for a hybrid Jag/JM pickup - basically a slightly lower, fatter Jag pickup with a steel base plate instead of the claw.
Any suggestions or other recommendations on that, I'm all ears. It's a bit of an experiment, so I'm open to ideas. The bobbins can be up to 7/8" wide: wider than a Jag but narrower than a P90 or a JM pickup.
If I make the SG-2 at the same time (which is looking very likely), I'll do it with Jag pickups in modified covers, as per the original plan. I still have one left from the original three I had Peter Leonard make for me - the other two went into the second Motorik.
chase
Post by chase » Wed Feb 16, 2011 8:54 pm
theworkoffire wrote:For the neck, I've asked for a hybrid Jag/JM pickup - basically a slightly lower, fatter Jag pickup with a steel base plate instead of the claw.
Cool. I'm very curious to hear how these'll turn out. How hot are you winding them? And have you thought about tapping them? Might be an interesting way to shift between thinner/thicker sounds...
noisepunk
Post by noisepunk » Wed Feb 16, 2011 9:15 pm
If the placement of these [pickups] were switched, you'd basically be building my dream guitar.
That sounds awesome to say they least, I can't wait to hear how they all sound; the Jag-master especially.
They tried to give me advice, down at the record shop. I said "Sit down boys, this may come as a SHOCK. But alls I listen to, it's all freedom rock."
surfin_bird
Post by surfin_bird » Thu Feb 17, 2011 1:05 am
For 680 euro's I would definatly buy it, in europe there hard to get
theworkoffire
Post by theworkoffire » Sun Feb 20, 2011 1:58 pm
My templates all arrived by Friday - fantastic service from RazorLAB (Ponoko's UK franchise), given that I only ordered them on Monday morning.
I've wangled a day without the kids on Wednesday to go wood shopping with a luthier friend - hoping to come back with enough for three projects 8)
chase
Post by chase » Sun Feb 20, 2011 5:33 pm
Really love the lines on that guitar. The pointy headstock works perfectly with the pointy horns.
shanetram
Post by shanetram » Tue Feb 22, 2011 9:28 am
That's going to look/sound killer when it's done. I've lusted after an sgv for a while but I'm not sure I can handle the tiny neck.
druunkonego
Post by druunkonego » Wed Feb 23, 2011 12:04 pm
I came across this today and thought of your build here. I guess its not exactly the same but it's close and pritty interesting.
http://cgi.ebay.com/RARE-VINTAGE-YAMAHA ... 1e61afa256" onclick="window.open(this.href);return false;
Cool build btw. You've always got some unique stuff cooking.
theworkoffire
Post by theworkoffire » Wed Feb 23, 2011 3:29 pm
druunkonego wrote:I came across this today and thought of your build here.
That's a Norma I think. They look great in sunburst.
The results of my timber shopping today:
I found a nice one-piece swamp ash blank that was just the right size. It's not particularly light, but it felt right. Also, a nice big neck blank and a rosewood board that will do me for two. Bought lots of other wood for other projects, too.
While I was there (David Dykes Luthier's Supplies) I saw some of the tuners I thought I was going to use for this (Gotoh 510s) and they looked completely wrong in the flesh. Much smaller than I wanted, so it's back to square one on that. If anyone can suggest some individual tuners that have large oval heads I'm all ears.
Also, I just dug out the bridge I bought (thanks to Luau) a while ago with this build in mind. It's a more modern Yamaha one from an SGV300, . The radius is far too flat, but the look is just about right. I'm going to have a good think about how I can modify it. I don't want to shim it, but I'm pretty sure I can just grind down the outer four saddles slightly and elongate the intonation screw holes downwards enough to make it 9.5, if not 7.25". Either would be fine by me.
And the meatier original:
theworkoffire
Post by theworkoffire » Wed Feb 23, 2011 5:27 pm
Hmmm. I've just measured the bridge and the radius is 9.5", but the string spacing is a bit too narrow - 51mm.
Looks like I'll need to make, or preferably find someone who can make me a new base with a slightly wider intonation screw hole spacing.
Britfingers
Post by Britfingers » Thu Feb 24, 2011 3:44 am
What's the purpose of the 4 phillip head screws on the original base Ben?
theworkoffire
Post by theworkoffire » Thu Feb 24, 2011 4:05 am
Britfingers wrote:What's the purpose of the 4 phillip head screws on the original base Ben?
They hold down little L brackets either side of the saddles to hold them all tight together.
frelonvert
Post by frelonvert » Thu Feb 24, 2011 6:17 am
theworkoffire wrote:Hmmm. I've just measured the bridge and the radius is 9.5", but the string spacing is a bit too narrow - 51mm.
I love those sg-2/sg-3 yamaha's, I can't wait to see your build going on ! it's gonna be a killer axe.
They are so rare in Europe.
I have a sgv300 and I'm looking after a saddle replacement, so if one day, you deceide to let go your sgv bridge, please let me know.
Post by Pacafeliz » Wed Mar 16, 2011 11:33 am
http://cgi.ebay.com/1966-ORIGINAL-YAMAH ... 45f8d9129a" onclick="window.open(this.href);return false;
oh wow people are insane... :whistle:
but a very lovely guitar, fer sure!
Pat.
ludobag1
Post by ludobag1 » Thu Mar 17, 2011 10:47 am
i don't know if it the same guitar but on surf guitar 101 you can have one for 750 bucks ;) more realist for me
