Yamaha SG-3 & SG-2 replicas - SG-2 Finished p15/18
Sonichris
Re: Yamaha SG-3 replica project build
Post by Sonichris » Thu Mar 17, 2011 12:58 pm
Yeah, the one on SG101 is pretty nice - here's the thread. It's not mine, and I'm not affiliated in any way. If i was in the market for one, this one looks to be a decent deal.
http://surfguitar101.com/forums/topic/14650/" onclick="window.open(this.href);return false;
mikethemod1992
Post by mikethemod1992 » Sun May 29, 2011 10:25 am
for the plate, were you just going to use a Jag plate? or get a custom job on that, aswell?
http://cgi.ebay.com/Fender-USA-Jazzmast ... 4837df2cdb" onclick="window.open(this.href);return false;
theworkoffire
Post by theworkoffire » Fri Nov 11, 2011 11:54 am
Amazing what a day without the internet inbetween jobs can do. I've still got a daunting amount of stuff to work out with this build but in the end I've just decided to go for it and see what I can come up with.
Roughing out the neck on the bandsaw:
And the body!
I've worked out that although my new thickness planer blade is only a foot wide, if I put a sheet of 6mm MDF down as a base I can send a whole body through with enough clearance between the pillars.
It just leaves a little raised section at the edge, which can be easily planed off by hand:
Template screwed on, using the pride of the fleet to do half the trimming one way:
Then flipping it over and exposing the bottom bearings to do the other half the other way.
Using my new best friend to make a start on the cavities. I'd only used it with its fixed base before this, so it took a bit of getting used to. Such a joy having a working vacuum attachment and a built-in light, though.
Swapped the template to do the rest of the cavities and the neck pocket. I didn't have time to run off my usual thicker MDF copies, so I ended up having to grind the end off a tiny bearing-tipped router bit to get right into the neck pocket corners.
And I had to use a couple of long thin follower bits to get right into the crook of the neck and the truss access hole:
Probably seven router bit swaps later - the most complicated pickup cavity I've ever seen:
Took me a while to work out how to do the Yamaha-style rounded edge. I bought (thanks Paul!) a fancy double-ended rounding bit, but the curve didn't seem quite right, so I dug out a big 7/8" radius roundover bit which seemed like a closer match, just using the tip of it:
The end result, after some hand-shaping around the neck area:
It still needs a bit of finessing - the arm and tummy contours, too, but it's nearly there. I might have over-rounded the transition between the rounded edge and the flat body a little, but it's not far off.
Re: Yamaha SG-3 replica project build - STARTED!
Post by Stereordinary » Fri Nov 11, 2011 3:42 pm
Hell yeah, that looks great! :-*
jingle_jangle
Location: San Francisco, California, USA and Natal, Brazil
Post by jingle_jangle » Fri Nov 11, 2011 4:50 pm
Fantastico! Great to see this one coming together...I'm a great Yammy offset fan...
Jazzprod
Post by Jazzprod » Sat Nov 12, 2011 5:05 am
I love this!!!
Looking good Ben!!
:w00t:
PoppaPopp
Post by PoppaPopp » Sat Nov 12, 2011 1:31 pm
That looks incredibly good. Wow.
"...if you can't punkify a Mustang then something ain't right in the world!" (UlricvonCatalyst)
ludobag1
Post by ludobag1 » Sat Nov 12, 2011 3:54 pm
nice ,isn't it :P
really love this shape :-*
therizzla
Post by therizzla » Sat Nov 12, 2011 7:29 pm
I would love one of these with JM pick-ups, wiring and trem! That would probably be my ultimate dream guitar!
reverb.
egosheep
Post by egosheep » Sun Nov 13, 2011 11:08 am
Awesome job, Ben! :?
garyptaszek
Post by garyptaszek » Tue Nov 15, 2011 5:41 pm
Ben your work is, as always, fantastic!
chase
Post by chase » Thu Nov 17, 2011 2:52 am
Post by the older brother » Thu Nov 17, 2011 6:33 am
Great work, as always, Ben!
There's some nice grain pattern going on on that piece of wood.
EvLoutonian
Post by EvLoutonian » Tue Nov 22, 2011 2:59 pm
This is absolutely excellent!
I can't wait to hear how the Narrow Range P90 pickups sound, too.
I've got my eye on them for a project.
The body is looking just fantastic.
EvLoutonian
Post by EvLoutonian » Tue Nov 22, 2011 3:00 pm
EvLoutonian wrote:I can't wait to hear how the Narrow Range P90 pickups sound, too.
Has anyone heard these pickups who can comment at this stage?
From the description, they do sound indeed sound like the perfect pickup for this guitar!
I did some experiments with a combination of both P90's and Seymour Duncan Jazzmaster pickups (hotter ones, with the bobbin plates ground down to P90 size) and trialed them in a guitar as two sets of humbuckers, but I didn't get particularly good results. But I love the idea.
