- Rgand
Of these, my preference is #4 because the straignt across PG ties the bridge to it. I do like it with the Vee string anchor holes.
- krib
Some progress with walnut neck for the walnut body posted earlier
- JakeNelson2002
nice work on the necks!
- Rgand
That walnut makes a nice looking neck. Looking good.
- JakeNelson2002
the round over is really what does it for me
now they are lookin like cabs
- Rgand
Those are really cool, Jake. Very nice work. Be sure to post a finished pic.
I concur! What are you using these for Jake? Homemade amps, or just building some cabinets to transplant an already built amp?
- Perry
Painted the pickguard a light tan color, similar to a light khaki pair of pants. Unfortunately, the color does not really show that well in the photo below. I've also been working on the neck, and that is close to having finish applied to it. I haven't decided whether to use an oil/varnish or spray lacquer.
- JakeNelson2002
They are cabs for homemade amps. I have transformers for 3 so far, and I made a couple extra cabs while I had everything set up, there was enough wood in 1 4 x 8 sheet that I couldn't stop So 2 are 14 x 16 x 9 (pro jr) 10" speaker, 2 are 16 x 18 x 9 1/2 (blues jr) 12" speaker, 1 is 18 x 20 x 10 1/2 (almost hot rod deluxe) 12" speaker. The Hot Rod will have a 6L6 version of Rob Robinette's Blackvibe. One of the BJs will be a 6V6 Blackvibe and I'm hoping I can stuff a Blackvibe in one of the PJ cabs for more of a travel rig. Eventually the other PJ will be a Blackface Champ and I don't have a plan for the second BJ cab yet. Next I'm going to prep a couple of these for paint like some of the fender amps but without the flowers or paisley.Shadoweclipse13 wrote: ↑Mon Jun 03, 2019 7:31 pmI concur! What are you using these for Jake? Homemade amps, or just building some cabinets to transplant an already built amp?
My brother is a welder/ machinist so ill stop by his place and bend the chassis for them all.
The PJ is getting the Eminence GA10-SC64 10", the HR is getting a Eminence Reignmaker (was looking for a mavrick but this came up cheap).
https://robrobinette.com/RR763_BLACKVIBE.htm
- Rgand
Nice. Perry! That pickguard looks good.
- lhwarp
-lhwarp
-lhwarp
- Rgand
Man, there are some beautiful cabinets happening these days. Those look great, Thwarp!
That is amazing all around! Make sure to post pictures of the amplifier electronics build, and well, just everything else. I, as I'm sure many other are, am very interested.JakeNelson2002 wrote: ↑Tue Jun 04, 2019 5:38 amThey are cabs for homemade amps. I have transformers for 3 so far, and I made a couple extra cabs while I had everything set up, there was enough wood in 1 4 x 8 sheet that I couldn't stop So 2 are 14 x 16 x 9 (pro jr) 10" speaker, 2 are 16 x 18 x 9 1/2 (blues jr) 12" speaker, 1 is 18 x 20 x 10 1/2 (almost hot rod deluxe) 12" speaker. The Hot Rod will have a 6L6 version of Rob Robinette's Blackvibe. One of the BJs will be a 6V6 Blackvibe and I'm hoping I can stuff a Blackvibe in one of the PJ cabs for more of a travel rig. Eventually the other PJ will be a Blackface Champ and I don't have a plan for the second BJ cab yet. Next I'm going to prep a couple of these for paint like some of the fender amps but without the flowers or paisley.
Also, woodworker's geeky question: do you have a circle cutting jig for the baffle speaker holes, or do you just wing it with something like a jig saw, and sand it to the mark later? I'm about to build a circle cutting jig for router, and I'm curious what you're using.
Ihwarp, those are awesome all around, but I LOVE your tolex color choice Two-tone with a vertical stripe
- lhwarp
Thanks Rgand and Shadoweclipse13 !
I do all this part-time, when I have time, so no production, only pure passion...
I have some hum issues to cure with the biggest one, the Serial Tone Killer - I absolutely can't stand hum ! - So he is not finished yet...
The 2 smaller are awaiting construction - I built these 3 cabs last summer : you see the picture... Of my slowness...
Some years ago, I have built several funny small amps...
The Orient-Express and the Val-King :
The Comet :
-lhwarp
The Comet :
-lhwarp
- Rgand
Those are all beautiful amps. Very fine work, there. I'd be hard-pressed to decide on a favorite.
