Thurston Moore JM Brass Conversion Thimbles, Mastery Bridge
Eduardo1990
Re: Thurston Moore JM Brass Conversion Thimbles, Mastery Bri
Post by Eduardo1990 » Thu Sep 19, 2013 5:39 pm
Uh....
Eduardo1990
Post by Eduardo1990 » Thu Sep 19, 2013 5:40 pm
^ that was the "shut up and take my money" image ::)
john999
Post by john999 » Sat Sep 21, 2013 8:45 am
Hi folks,
Been a bit of interest lately so thought I would chime in after a bit of a break. Been busy building other stuff on MLP forum after an irresistible urge to build a '59 LP Burst replica, and a couple of P-90 Tele's.
I am in the middle of selling up in London and set up on the south coast, with proper workshop in the next few months.
antisymmetric
Post by antisymmetric » Sat Sep 21, 2013 11:11 am
Hey John, good to see you back around! Any chance of posting pics of or links to these LP and Tele projects of yours?
john999
Post by john999 » Sun Sep 22, 2013 12:21 pm
antisymmetric wrote:Hey John, good to see you back around! Any chance of posting pics of or links to these LP and Tele projects of yours?
Thanks mate, good to hear from you, see what I can do over the next few weeks, winter evenings etc. The LP post is long! :unsure:
Cheers, John
gafenderboy
Post by gafenderboy » Mon Sep 23, 2013 12:05 pm
Just ordered a set of these thimbles from John for my TM JM. Really looking forward to getting them and installing a Mastery w/o drilling/doweling, etc. Will definitely report back but up to this point John has been nothing but helpful!
john999
Post by john999 » Thu Sep 26, 2013 5:26 am
Thanks mate, heres some links to My Les Paul Forum posts of the recent builds,Distinct lack of Offset content, so not sure if worth posting as a new thread on OSG, let me know.
(Links deleted, as didn't work! :derp: )
Workshops semi packed away and stored away in my spraying shed whilst I sell up in London, this winter hopefully. Looking for somewhere with large garden, garage, and very large shed. (Hopefully Bournemouth Dorset) More soon.
Cheers, John
PS "Gafenderboy" the brass conversion bushes are in the post and on the way. Let us know how the fitting went, remember the tap them all the way down in the body. Thanks & good luck mate, should liven the TM up a bit.
antisymmetric
Post by antisymmetric » Mon Sep 30, 2013 1:30 am
Those are all stunning John. Amazing attention to technique and detail as always, and I always learn stuff from your threads. Drilling to join the chambers in the Teles- I'm going to remember that trick for the (eventual) Telecaster-like object in my own project list.
Nice one. 8)
john999
Post by john999 » Thu Oct 03, 2013 2:08 pm
DELETED
Kostas
Post by Kostas » Thu Oct 03, 2013 3:14 pm
Any chance you can post the build links again John?
john999
Post by john999 » Fri Oct 04, 2013 12:38 am
X
john999
Post by john999 » Sun Oct 06, 2013 10:04 am
X
noctisariel
Re: Thurston Moore JM Brass Conversion Thimbles, Mastery Bridge
Post by noctisariel » Fri Jan 03, 2020 9:44 am
Taking a long shot here John (considering this post is pretty old), but what are the chances I could commission a set of these beauties from you? I'm desperately trying to get my AOM bridge swapped out for a Mastery I picked up, and would really prefer to avoid doweling the body at any cost. Thanks in advance, and happy 2020 to you!
Danley
Post by Danley » Fri Jan 03, 2020 10:49 am
So I didn’t create new bushings, but I was able to drill out stock AOM bushings to fit Jazzmaster bridge cups. This was done to fit a stock Jazzmaster bridge (not Mastery) but assume it could work the same way for you, though it’s perhaps a bit ghetto at first glance it’s an invisible and reversible retrofit. They do work:
The one on the right has no cup, but is drilled.
Assembled, no problems, perfect tuning/location of the strings and bridge.
noctisariel
Post by noctisariel » Fri Jan 03, 2020 11:12 am
Hey Danley - appreciate you sharing. Perhaps not as elegant, but definitely a solid solution. Just so I'm understanding correctly - you drilled the existing AOM threaded thimble cavity to open it up to receive the second thimble for the vintage bridge? Just want to make sure I'm interpreting your images correctly. Thanks!
