Neck Builds (Now With Truss Rod Jig Plans: Page 3)
- Strider13
Hey everyone, just thought I'd start a thread showing everyone how I go about making a guitar neck. I've learned a lot about methods for building them from this forum and the TDPRI, but it's mostly been in bits and pieces. I haven't really seen a thread demonstrating a two piece neck build from start to finish. So I figured that I would start one myself, in order to help others that may want to start building necks themselves. I hope other members will chime in with their own methods, so we can make a consolidated thread of neck building techniques. But that's enough of an introduction, let's get building!
www.factionguitars.com
- Strider13
Rough Shaping The Neck Blank
I start out by tracing my neck template onto the pieces of 3/4" thick maple I'll be making the necks out of. Two of the blanks are regular hard maple, and the other one is flamed maple. When tracing the neck, I try to avoid knots and any defects that may be in the neck blank.
I used a large forstner bit to drill some relief holes around the nut in the neck blank.
I then use my bandsaw to rough cut around the neck, about 1/8" to 1/16" around the perimeter.
I then move over to the spindle sander to sand even closer to the line. I use the round drum attachments to shape the inner curves around the headstock, and the belt attachment for the flat parts and outside curves.
- Telliot
Re: Neck Builds
Awesome! Thanks for starting this thread! I'd really like to start making necks, but I'm pretty intimidated by the idea. It just seems so easy to eff up... I hope you can show the process using everyday tools for those of us (me) who haven't the specialized equipment.
- PoppaPopp
Re: Neck Builds
Thanks again Strider - it's greatly appreciated!
"...if you can't punkify a Mustang then something ain't right in the world!" (UlricvonCatalyst)
- Strider13
Shaping The Neck Profile Further
I then screw my template onto the neck blank with some 1-1/4" drywall screws. The holes are located where the truss rod routs will go, or in the case of the headstock, where one of the tuner holes will go. I shortened the screw near the first fret to about 1" long, so that it doesn't go too deep that it leaves a hole when we shape the neck later on.
With the template firmly attached, I take the neck over to the drill press and use my set of robosanders to sand even closer to the line. I want the router to have to take off as little material as possible, so we get a smoother cut without tearout. I use the larger drums to sand the majority of the neck, and the smaller one to get into the inner curves of the headstock. I also get the heel end nice and smooth and to the line. I don't like routing around the neck heel, as no matter what it seems to want to grab a corner and tear it out. So I just use the robosander to get the area around the heel where I want it, and don't rout it at all.
I set up my spiral cut router bit in my router table, the same bit I use for routing bodies. I also set up the router fence, with the bit guard above the tip of the router bit. This makes the routing a bit safer.
I rout the profile by pushing the wood against the cutter (From the right side of the table towards the left) as I'm not a big fan of climb cutting (routing with the spinning direction of the cutter). By using the sanders to get so close to the line before, I don't have to worry too much about cutting against the grain, so I'm able to rout everything more safely by avoiding climb cuts.
The finished profile looks something like this:
And here are all of the necks together, next to the AllParts Jaguar neck I'll be using as a reference for these builds.
- blacktiger
Re: Neck Builds
I doubt that I'll ever attempt to make a neck in my life, but this thread is awesome nonetheless. It's always cool to see how things are made.
Thread killer
- Strider13
Re: Neck Builds
Telliot wrote:Awesome! Thanks for starting this thread! I'd really like to start making necks, but I'm pretty intimidated by the idea. It just seems so easy to eff up... I hope you can show the process using everyday tools for those of us (me) who haven't the specialized equipment.
Glad to hear there's some interest! It is a bit intimidating at first, but gets easier when you know everything that needs to be done. I have access to a lot of tools, but most of what I am doing can be adapted for those without access to a large shop. A jigsaw can be used instead of a bandsaw, regular sanding drums and a belt sander can be used instead of a spindle sander and robosanders, etc. The specialized tools can make things easier, faster, and more reliable, but most of them aren't necessary. No matter what tools you end up using, the basic techniques and ideas should stay roughly the same.PoppaPopp wrote:Thanks again Strider - it's greatly appreciated!
- Strider13
Re: Neck Builds
I've made a lot more progress on these necks, but I'll have to wait until after work to get some more photos and writing up on the thread. Glad to hear that everyone is interested in the process though.
- willc
Re: Neck Builds
Outstanding!!!
This great to document.
I have been wanting to make a neck for a bit now and hopefully this can help out.
- maximee
Re: Neck Builds
Hey Strider13,
thanks for your time and effort! Very interesting read, can't wait to see more!
- cmatthes
Re: Neck Builds
Awesome thread! Thanks for sharing...
- CROSS_guitars
Re: Neck Builds
Yep. Got all that but what about peoples' trussrod installation techniques?
- Strider13
Re: Neck Builds
I'll get to truss rod channel routing, truss rod building, and truss rod installation over my next few posts. My truss rods are vintage style, single action, which makes them pretty easy and cheap to build.CROSS_guitars wrote:Yep. Got all that but what about peoples' trussrod installation techniques?
- Tree's
Re: Neck Builds
Thanks for sharing , good point on not using the router on the heel. Made me realize, all the vintage necks I've owned had some bit of vertical saw lines still visible on the heel. Fender didn't rout around the heel to avoid tearout also.
- lokalfuz
Re: Neck Builds
This is awesome indeed. Thanks much!
