wood types / wierd project!
fourmations
Post by fourmations » Wed Sep 05, 2007 5:13 am
hi all
i am making a travel guitar
I just want a really quiet thing that I can
diddle about on, practice scales on the beach, etc
so........
I am using an electric guitar bolt on neck
and literally attaching a plank with a bridge to it
I was wondering what wood i could use for this plank
bearing in mind I want to keep it light for travel,
whats a good light wood that will take the tension
I will string it with electric 10-46
i have access to decent tools here in work
and will route a neck pocket in the "body"
and put it together at my destination
afterthought... could i use aluminium?
light, rigid, mmm...
any advice welcome
rgds
4
Re: wood types / wierd project!
Post by Stereordinary » Wed Sep 05, 2007 8:44 am
Alder, Poplar, Pine or Ash would be my recommendations.
Save up for your dream guitar.
fourmations
Post by fourmations » Wed Sep 05, 2007 8:51 am
thanks for that stereo
another question...
on the neck in question the screws are splayed out..
(the neck plate does not match up with the neck holes at all!!)
but when its all together its perfect, the holes were drilled at an angle
from the back of the body into the neck
so, its going to be hard for me to drill my "body" to suit
as i cant really measure the angles
I think i can get it with a bit of thought.. but
if i were to mess up the existing holes in the neck
is it easy to fill them and redrill, what the product to use
(uk / european)
the neck will be going back on its proper body
when i'm back off my hols
this neck is off an old aria pro 2 335 copy which is not an amazing guitar
but i have had it for 15yrs and dont want to render it useless
rgds
4
Post by Stereordinary » Wed Sep 05, 2007 8:55 am
Plugging and re-drilling holes is fairly straight-forward.  You can use virtually any wooden dowels and regular wood glue, after you drill the appropriate-sized hole.
Stratelejazzuar
Post by Stratelejazzuar » Thu Sep 06, 2007 11:10 am
maybe you could just plug the neck holes and then drill it to fit the neck plate... that way you won't have to try, plug, try again... etc.??
that's what i've done for 3-4 of my proj guitars in the past (changing 3 bolt strats to standard 4, etc)
:D
fourmations
Post by fourmations » Thu Sep 06, 2007 11:38 am
thanks for the wisdom guys
the minor dilemma is that I want this neck to go back on the guitar
so the holes are splayed on the body original body too.
so, i would need to plug the neck, drill out the travel body
and plugged neck at the same time, and the off on my hols
then plug the body and drill that in line with the holes
that were drilled for the travel body
whoah gotta post, my kids after the doodlebops website  ::)
rgds
4
