Updated PSVI mods including Conversion Guard, bridge, mute
- mcjt
Re: Updated PSVI mods including Conversion Guard, bridge, mu
awesome! thanks, Sneaky! i have a black PSVI that i would like to modify. i'll be in touch.
- SneakyT
sounds good
Troy Neagle Luthiery & Custom Pickguards
Please contact me at Reverb
https://reverb.com/shop/neagle-luthier
- SneakyT
New camera new pics of parchment guard
And one of the F neck plate.
- bassVIst
just beautiful...
really loving all these mods to these!
whether it's making it look *right*, like this...
or taking it even further out there!
- MurrySandstorm
Whoa! Your bass looks amazing with those mods! Absolutely stunning! I also have a PS VI in candy apple red but the high shine on yours is killer. I love my bass vi but the addition of the control plate and the single coil bridge pick up really improves the overall look. Kind of surprising how much of an impact those 2 changes make. Never mind the new bridge and cool foam mute! You did a great job! Congrats!
- Sidus
First of all, welcome everyone, this is my first post here.
SneakyT, is there a possibility you could record how the PSBVI sounds with the mute engaged? I'd really love to hear how it sounds in action.
Also, you have flatwounds installed, right?
Cheers.
Cheers.
- SneakyT
Thanks man!MurrySandstorm wrote:Whoa! Your bass looks amazing with those mods! Absolutely stunning! I also have a PS VI in candy apple red but the high shine on yours is killer. I love my bass vi but the addition of the control plate and the single coil bridge pick up really improves the overall look. Kind of surprising how much of an impact those 2 changes make. Never mind the new bridge and cool foam mute! You did a great job! Congrats!
I'm not sure when I'll have time to record any demos. Though not the greatest demo this guy uses the mute at about 1:06. I'd stop watching the demo after that. https://www.youtube.com/watch?v=ciZgPK4fsHASidus wrote:SneakyT, is there a possibility you could record how the PSBVI sounds with the mute engaged? I'd really love to hear how it sounds in action.
No, I find flats very limiting especially on the Bass VI. I use Circle K strings on both of my VI's. DR sunbeams on most all other basses. I do have one Pbass that lives with flats in case I need that tone in the studio.Sidus wrote: Also, you have flatwounds installed, right?
- SneakyT
Have had a few questions about which pickups I'm using in this so I thought I'd post it to make it more clear. I kept the original neck and middle pickups but moved the neck to the bridge position. I installed an AVRI Jag pickup in the neck. The original neck PU in the bridge works very well due to it being hotter than the new one. I'm very happy with the neck and bridge though I may get an AVRI for the middle as they seem to be a little more open sounding.
- mtwtrf
Re: Bass VI Bridge Mod
Is the mustang bridge wider? I'm having trouble intonating my low E... joining the club.stilettoace wrote:I'm building a bass VI right now. Being able to simply pick up a mustang bridge for it makes the trickiest part easy.
Thanks a bunch!
- SneakyT
The mustang bridge is the same as the pawnshop bridge. In this order I would try these things when trying to intonate a Bass VI with the smaller 3/4" bridge. First turn the bridge upside down with the adjustment screws towards the pickup rather than the trem. If that doesn't work then try shimming the neck which through the new geometry will add a small amount to the overall length to the total scale thus helping intonation. Lastly the mod that I did to the original bridge will add another small amount to total length. I am currently using a 3/4" Staytrem bridge upside down that has no problem intonating after a shim to the neck.mtwtrf wrote:Is the mustang bridge wider? I'm having trouble intonating my low E... joining the club.stilettoace wrote:I'm building a bass VI right now. Being able to simply pick up a mustang bridge for it makes the trickiest part easy.
Thanks a bunch!
- kenstee
So, all in all, what did the mod cost in total? Parts, etc.
- SneakyT
Around $165 not including bridge and mutekenstee wrote:So, all in all, what did the mod cost in total? Parts, etc.
Pickguard $60
Plates $50
Pickup $40
Switches and pot around $15
Total
Bridge $100
Mute $40
- SneakyT
Pickup windings.
So recently I changed the volume pot out to a 1 meg and it really showed how limiting middle and bridge (original neck) pickup are. I decided to take some measurements on them to see why they were lacking in the high end. The AVRI that I have in the neck position was 6.8k and it sounds great. The middle was 14k and the bridge was 12.8k. So I decided to change that and got to work unraveling the middle pickup. I unwound it to right at 8k. It now matches the tone of the AVRI really well. Much more chime and shimmer. The bridge will be next. I'm thinking of starting at 8.5k and seeing if it needs any more removed.
- Marc
Hi as this thread is a little old can I confirm that I approach Rutter Guitars to order the two chrome plates and Mr Sneaky for a PS VI conversion pickguard? Is this still correct?
- zip73
Yep, just did mine a little over a month ago. Both Rutters and SneakyT are great guys to deal with.
