Difference between Japan and AVRI Bridge Thimbles
Jazzprod
Post by Jazzprod » Mon Feb 22, 2010 12:24 pm
AVRI on the LEFT, Japan made on the RIGHT:
Height with crown: 22,2mm VS 21,5mm
Height witout crown: 20,5mm VS 20,0mm
Depth: 19,4mm VS 18,4mm
Width tube: 9,5mm VS 9,0mm
Width crown: 12,5mm VS 12,0mm
theworkoffire
Re: Difference between Japan and AVRI Bridge Thimbles
Post by theworkoffire » Mon Feb 22, 2010 12:46 pm
I don't mean to be an arse, but do you have your left and right muddled?
Jazzprod
Post by Jazzprod » Mon Feb 22, 2010 1:42 pm
Haha.. yes.
Edited
staytuned
Post by staytuned » Mon Feb 22, 2010 1:48 pm
this helps alot! thanks!
In-Sound
Post by In-Sound » Mon Feb 22, 2010 3:53 pm
Big thanks for the info. This can aid people wondering if they need the Japanese sized posts for their Mastery bridge. I'll go measure mine now... ;)
Both the thimbles on my JM(Japanese, serial was sanded off neck before I got it) have a crown diameter of 12.0mm; Consistant with your measurements for the Japanese thimbles. The internal diameter (measured across the top, from inside edge to inside edge) is 8mm.
??? So if the Japanese thimbles are smaller in size, why are the "Import Sized" Posts for the Mastery discribed as being larger ???
Same bridge as above, but with an additional set of larger mounting posts required for some Japanese made instruments.
What is this third thimble size? Can anyone provide an answer? (I'm checking my Mustang to see if it holds the key...)
Mustang (CIJ Competition RI, Serial P088689) thimbles 12.0mm Crown Diameter but a internal diameter of 8.0mm... No help here.
Bridge Posts are 6.5mm for Mustang, 6.0mm for JM meaured across the underside of the post (where the height adjustment screw comes out)
bubbles
Post by bubbles » Mon Feb 22, 2010 6:28 pm
FYI. I recently ordered the Mastery Bridge for my CIJ '66RI JM, and paid the extra for the extra thimbles....turns out they were unnecessary, for me at least...the "made for import" posts were too fat for my guitar. Mine is either an '04 or an '05 (cant exactly recall),
SN: R069591
nice to post this info though!
In-Sound
Post by In-Sound » Mon Feb 22, 2010 6:47 pm
SN: R069591
Would you be willing to take measurements of your thimbles and, if you still have them, both sets of mastery posts? I think that would clear up any confusion I'd have on the subject.
Jazzprod
Post by Jazzprod » Tue Feb 23, 2010 12:42 am
I have a Mastery bridge at home and while the AVRI thimbles is a snug fit, the japanese is not. It tend to rock and move in the japanese one.
Hope that helps.
wardpike
Post by wardpike » Tue Feb 23, 2010 8:02 am
Japanese thimbles are made by Toyota and suffer from electronic problems causing your brakes to fail. Or so I've heard.
ringworm
Post by ringworm » Tue Feb 23, 2010 12:43 pm
Jazzprod wrote: It tend to rock and move in the japanese one.
I was going to ask about this in a new thread... the thimbles in my CIJ rock from a vertical position to a very slight angle away from the pick ups.
Is this normal? I thought they should sit in tight.
Jazzprod
Post by Jazzprod » Wed Feb 24, 2010 12:38 am
If you use a Mastery Bridge, it should be tight. If you use a stock bridge, it should rock.
ringworm
Post by ringworm » Tue Mar 09, 2010 5:42 am
Thanks for that. Good to know.
Post by the older brother » Tue Mar 09, 2010 5:51 am
Jazzprod wrote:If you use a Mastery Bridge, it should be tight. If you use a stock bridge, it should rock.
STOCK JM BRIDGES ROCK! 8) :D
