Case for Fender XII
akpasta
Re: Case for Fender XII
Post by akpasta » Tue Jan 29, 2019 11:34 am
Hi Folks,
Sorry to resurrect this thread but I am considering a new case for my 66' Electric XII. I HAVE the vintage case, but it slops all over inside and is no good for transport- I move the thing around in a gig bag which is better.
I contacted G&G but haven't heard back.
Those of you with G&G XII cases, do you have any photos? Does the guitar sit SNUG inside and not slop around?
offkeyericdee
Post by offkeyericdee » Thu Jan 31, 2019 6:38 am
Hi Folks,
I have two G&G XII cases and both fit the guitars very snugly without them bouncing around whilst moving. Those cases are a good investment.
"If it's not a Fender, you f**ked up!"
-1968 ad slogan
akpasta
Post by akpasta » Thu Jan 31, 2019 7:10 am
Hi Folks,
Thank you for the feedback! Are there any photos of these cases online?
DaddyDom
Post by DaddyDom » Sat Feb 02, 2019 7:19 pm
Mine is a close fit, are you sure it's the case that was meant for it? Not a bass case?
DD
jaapbossen
Post by jaapbossen » Mon Feb 04, 2019 3:00 am
You can also use a SKB Jazzmaster case. My XII fits in there nicely!
hornz
Post by hornz » Fri Feb 08, 2019 8:31 am
Hi Folks,
What are the external dimensions of your XII case? Although not as sturdy as the reissues it should be a good fit for the guitar. It's not a P/J Bass case is it?
hornz
Spin The Black Circle
akpasta
Post by akpasta » Fri Feb 08, 2019 8:53 am
Hey Y'all. Just to clarify, it "FITS." Like it's the correct case and the guitar fits inside and the case closes, it just doesn't keep the guitar very safe. Like, the guitar rattles around inside and the headstock bangs against the sides because the neck support is just flat. The case doesn't hug the guitar like new cases do. Basically, a gig bag is better, and that's no good when you've got such an expensive guitar.
I e-mailed G&G and haven't heard anything back. Are they usually pretty bad about custom orders?
hornz
Post by hornz » Fri Feb 08, 2019 3:12 pm
OK, cool re. your original case.
G&G are usually pretty good - give them a DM on Instagram and they'll probably respond on there pretty quickly.
hornz
gibs
Post by gibs » Wed Jan 19, 2022 5:34 pm
Sorry to resurrect, but I’d an skb JM case works I’m good. I’m thinking about building a 6 string xii so basically a maverick neck, and figured finding a case would be…… expensive. This thing ain’t gonna be anything expensive, and I don’t need form fit, just tight enough to where it fits but isn’t bouncing around.
SignoftheDragon
Post by SignoftheDragon » Thu Jan 20, 2022 12:10 am
The Gator JM-JAG case fits (very snugly) for just over $100, but the Crossrock Jazzmaster case is the best fit I've found. About $140 shipped from Reverb.
Post by Pacafeliz » Thu Jan 20, 2022 1:31 am
Lemme check the cases of my Maverick and Custom, I seem to remember they fit good - at least one of them is a good fit. Stay tuned.
Post by Pacafeliz » Thu Jan 20, 2022 9:31 am
Well yes this is a Road Runner case, dunno the model, but it fits the Mav nicely.
...or is the XII's headstock even larger?
Post by Pacafeliz » Thu Jan 20, 2022 9:35 am
...if it IS bigger/larger, this Rockcase might be a better/perfect? fit.
Lemme know if you want me to measure anything...
gibs
Post by gibs » Thu Jan 20, 2022 9:39 am
The mavericks just used regular electric xii necks that they filled the extra tuner holes on and veneered the headstock to cover the fillers. So it should be the same as an electric xii, unless later models that had factory fresh necks shortened the headstock up. My only worry is the bottom half of the body being a little shorter, since the cuts in the body could have removed some of the overall length, as again, the maverick took existing electric xii bodies and bandsaw to a few spots on the body.
Tele295
Post by Tele295 » Thu Feb 03, 2022 9:11 am
I used to carry my ‘66 XII in an old Gibson short scale shaped Bass case. I miss that case almost as much as the guitar.
Jill Martini & The Shrunken Heads - all aloha, all the time
