Hello, I just need some help/explanation to figure out what is compatible.
These are the 2 heads
--Fender Bassman 300--
Output-300 Watts @ 8, 4 or 2 ohms
--Orange Thunderverb 200--
Output-200w (RMS)
Speaker-2 x 4 ohms, 2 x 8 ohms (200w) or 2 x 8 ohms, 2 x 16 ohms, 2 x 16 ohms (100w)
1. Can I use this cab for either of the heads and be safe? Will I get the maximum wattage out for each head?
--Orange PPC 412 HP 8--
Output-400 w (RMS), 8 ohms / 2 x 200 w (RMS), 16 ohms
2. Can you help me understand how to figure it out?
I see that the number of ohms match but I am confused when I see "8 ohms / 2 x 200 w (RMS)" and " 2 x 8 ohms (200w)"
Thanks so much for the help.
Help with ohms and amps...
- Dorianz10
Former instrumental band-no longer active
www.myspace.com/figureoffiends
Re: Help with ohms and amps...
wait..... the cab is 400w at 8 ohms right?Dorianz10 wrote: Hello, I just need some help/explanation to figure out what is compatible.
Output-200w (RMS)
if so you could use your bassman head with it switched to 8 ohms.
