Bass VI amplification
- Mighty Tom
Simple question:
Do I need to use a bass amp for a Fender Bass VI, or can I use a guitar amp without blowing it up?
Re: Bass VI amplification
you can use either..Ive never harmed a guitar amp yet with one..
- Mighty Tom
Interesting. I hope you're right! I'd hate to destroy my Vox.
- pullover
I use a super reverb with my Jag Baritone and it works fine. Start out low and slowly raise the volume, you can tell when you're getting too loud and are doing damage.
- Mighty Tom
I can? What are the signs?
- zhivago
- Mighty Tom
Uh... I think the next step after that would be to take it in for repairs. Wouldn't the damage be pretty much permanent by that point? If I understand what you're describing correctly, the same thing happened when I decided to play my P-bass through my Peavey Ultra 60 head. Bad move on my part. Had to have the tubes replaced.
I play bass and bass vi's through all manner of guitar heads and cabs..ive never caused any damage..I could imagine that its easily possible to damage a small poorly rated speaker with too much bass but surely you can put whtever you want through a head of any sort..I record Bass (not bass VI) usually through a 70's marshall guitar head and 4x12..I'm sure any combo worth it's salt would be able to handle bass...if the speakers fart n flap then I guess that's the sign to back off the volume.. anyway we're talking bass VI not real bass anyway..Bass VI's are not as bassy as a proper 4 string bass..
I seriously doubt playing a bass through your peavey head damaged the tubes..I do think the extra energy of the bass frequencies probablycould push an already bad tube over the edge though.
- pullover
Like Eggwheat said, if you hear it farting out, turn it down. The only real difference between a bass amp and a guitar amp is that guitar amps have a lower speaker rating so that they break up earlier. Too much break up with basses can blow the speaker.
Carol Kaye (of beach boys fame) played a Fender p-base through a Super Reverb.
Another person who used guitar amps rather than bass amps
Edit: Since bass takes a lot more power to produce its volume your not going to get the same volume level out of a bass. If you crank it too much, you're going to blow your speakers.bassplayer.com/article/brian-wilson/oct-04/860 wrote:...Carol favored a Fender Super Reverb, which had a 4x10 speaker configuration and an open back. She laughs, "I used to have to stick matchbook covers in the back so the bottom panel wouldn't rattle." Wilson would place a Shure 626 mic right up against the top-right 10" speaker.
wikipedia wrote: Chris Squire of Yes produced his classic bass guitar sound by playing through a guitar amplifier with its bass turned down, treble turned up, and volume turned up well into distortion; the miked guitar speaker signal was then mixed with a direct-inject (DI) signal, a technique that has been used for processing synth keyboards as well. A bass guitar can also be played through a bass amp in parallel with a distorted guitar amp by using a DI box, producing complex breakup yet well-defined lower frequencies. http://en.wikipedia.org/wiki/Guitar_amplifier
- OffYourFace
When I finish my Bass VI i'm going to get an old Peavey Musician Mark III (w/ built-in phaser). That's what Robert Smith uses for his Bass VI, the Disintegration sound
