I can't for the life of me figure out the ohms thing...so if someone could help me out...
I have a 2x10 cabinet which is rated "4 ohms"
Inside (opened it up today because I blew a speaker and am going to get it reconed), there are 2 8 ohm speakers...
this is normal, right? By the way it is an Eden 210 XST.
I wonder because I've seen 4 ohm speakers for sale, which would, by the same logic, have to be for a 2 ohm cab, which is something i've never seen....
quick ohms question
- sonik
- blacktiger
Re: quick ohms question
Depends on how you wire them, in series, or parallel (or with 4 or more series-parallel). Most American amps tend to be wired in parallel, so two 8 ohm speakers would yield a 4 ohm load. The same speakers wired in series would yield a 16 ohm load, common on amps like Vox AC30s. To keep it simple, in a two speaker set-up wiring in parallel will give you a load that's half the impedance of what a single speaker is rated for. Wiring in series will double the impedance of what a single speaker is rated for. If you want to know about it in more depth than that, someone else will have to chime in.
Thread killer
- sonik
okay, that sounds about right...thanks!
- danoisefactory
ok, some more info from this thread:
index.php?topic=7794.15
danoisefactory wrote: Let's say you have two speakers:
there 25 watt, 8 ohm.
That means that wether you wire'm parallel or serial, the resulting cabinet is 50 watts.
When wired in parallel the ohmage is:
1/8 + 1/8 = 2/8 (then turn around, just lke resistors) = 8/2 = 4 ohm.
when wired in serial it is 8+8 = 16 ohm.
So if you get speakers there are 16 ohms, you can wire them parallel and you have 8 ohms!
If you have speakers that are 4 ohms: 4+4=8 ohms!
But if you have 8 ohm speakers, you can not make two of them become 8 ohms.
here is some info:
http://colomar.com/Shavano/speaker.html
http://colomar.com/Shavano/spkr_wiring_sp.html
http://colomar.com/Shavano/spkr_wiring.html
http://colomar.com/Shavano/stereocab.html
and more:
http://colomar.com/Shavano/construction.html
