Can I use a 4ohm attenuator (weber minimass for example) between my Vibro Champ and the Weber speaker i have in it ? Makes me wonder because the Champ and the speaker are both 3,2ohms. Does the speaker mind in case it sees a bigger load than it should because of the 4ohm attenuator? Are speakers sensitive about too big ohm levels?
I´m not quite sure if the attenuator actually changes the ohm level or if it remains the same all the way to the speaker...
At least the amplifier part should be ok since it won´t see a smaller ohm level than it´s been designed for.
6 watt Vibro Champ with attenuator- WHY?? you ask. Because i need to get some natural crunch at home, at apartment levels... and this little bastard is REALLY LOUD when dimed.
Thanks in advance.
