Some circuits need them, others do not, so they arent always used. Some builders slap them on everything just because its a 1 cent part and why not.countertext wrote: ↑Sat Jan 27, 2024 6:46 amAre pull down resistors designed into the circuits of some builders and not others? Is it common in the industry, or maybe not done at all? I know the sound of a pedal popping, but I never thought about it until reading this thread.Dr Tony Balls wrote: ↑Wed Jan 24, 2024 12:52 pmCause: Stray voltage on the switch.
Remedy: Pull down resistors at the in and/or out of your pedal circuit.
http://www.muzique.com/news/pulldown-resistors/
Footswitch pop - causes and remedies?
- Dr Tony Balls
Re: Footswitch pop - causes and remedies?
Instagram: thetonyballs
- countertext
Right on.Dr Tony Balls wrote: ↑Sat Jan 27, 2024 7:13 amSome circuits need them, others do not, so they arent always used. Some builders slap them on everything just because its a 1 cent part and why not.
- DeathJag
I think I figured out my problem - the input was way too low and all amp noises were way louder than normal. I pushed the levels up and the pop got super quiet. It is still there but I doubt I'll hear it unless switching when not playing.Dr Tony Balls wrote: ↑Fri Jan 26, 2024 8:43 amThere is nothing inherent in a tremolo effect pedal that will cause pop. Its possible that all of the ones you tried lacked pull-down resistors when they needed them. There's no need for an extra in-line box if everything is built proper.
But, I did measure an average of 100ma of DC between the tip and sleeve of the input of the reverb tank. Rather than build something as a band-aid, I'm going to try and eliminate that VDC! Both amps measure 0ma at their input. That will take some time as I'm a complete dummy. The other dude said he lifted the input resistors off the board on onto the jacks and then the DC was gone.
