Re: Setup of the day
- luau
- Admin
Spending a little time with my old '76 Custom today with one of my typically wild setups.
- Jonesie
So the Barbershop goes well with the Ampeg thing? I have an old Jet that I love and it's definitely a bit finicky with OD's. I'm using a double rock right now, which sounds fantastic, but I'm always looking for something else. Is the Barbershop a Morning Glory / Bluesbreaker real low gain type thing?garyfanclub wrote: ↑Thu May 12, 2022 10:40 amKeeping it super simple this afternoon…
75 Tele Custom > Fairfield Barbershop > 65 Ampeg Reverberocket 2
The onboard effects on this amp are just about everything I need. If it had onboard vibrato I’d be completely set.
- garyfanclub
Works great! I use it for sort of Zuma-era Neil Young type tones on lead breaks and it does the trick. The Barbershop is pretty versatile, as the Sag knob can take it from tweedy crunch on to the far left (CCW), to loud and transparent clean boost when pushed fully CW. Best to think of the Sag knob as a voltage knob, left is starved and browner sounding, right is cleaner and tighter, so that function really defines the character of the pedal. Adjust Drive to taste from there. The Volume and Sag are interactive, so if the volume is a bit low with the Sag turned CCW, turn up the volume and you'll get some crunch back. I'm not a high gain guy and it's got plenty of juice for my purposes.Jonesie wrote: ↑Thu May 12, 2022 12:39 pmSo the Barbershop goes well with the Ampeg thing? I have an old Jet that I love and it's definitely a bit finicky with OD's. I'm using a double rock right now, which sounds fantastic, but I'm always looking for something else. Is the Barbershop a Morning Glory / Bluesbreaker real low gain type thing?garyfanclub wrote: ↑Thu May 12, 2022 10:40 amKeeping it super simple this afternoon…
I've also got a Morning Glory, not really my cup of tea - I find the BS to be much more unique and amp like rather than "pedally" like the MG. Maybe I should give the MG another shot? I don't think the BS is based on anything in particular, to my knowledge.
- Jonesie
Awesome, thank you! I just got rid of my MG recently, I liked it at first, but the more I played it the more I realized I just kinda liked it as a clean boost, and even then it was a bit "hi-fi" for my taste.garyfanclub wrote: ↑Thu May 12, 2022 12:50 pmWorks great! I use it for sort of Zuma-era Neil Young type tones on lead breaks and it does the trick. The Barbershop is pretty versatile, as the Sag knob can take it from tweedy crunch on to the far left (CCW), to loud and transparent clean boost when pushed fully CW. Best to think of the Sag knob as a voltage knob, left is starved and browner sounding, right is cleaner and tighter, so that function really defines the character of the pedal. Adjust Drive to taste from there. The Volume and Sag are interactive, so if the volume is a bit low with the Sag turned CCW, turn up the volume and you'll get some crunch back. I'm not a high gain guy and it's got plenty of juice for my purposes.Jonesie wrote: ↑Thu May 12, 2022 12:39 pmSo the Barbershop goes well with the Ampeg thing? I have an old Jet that I love and it's definitely a bit finicky with OD's. I'm using a double rock right now, which sounds fantastic, but I'm always looking for something else. Is the Barbershop a Morning Glory / Bluesbreaker real low gain type thing?garyfanclub wrote: ↑Thu May 12, 2022 10:40 amKeeping it super simple this afternoon…
- 46346
man i love the Reverberocket 2! it was the first vintage amp i restored, back in the 90's and still among my more trusted gigsters.
i also have two 60's Jets, and all three Ampegs have taken overdrives very well.
in fact i was kind of shocked at the roaring rich tone that came out of my first Jet when i plugged a Fulldrive 2 into it!
let me know if i can help. i restored the RR2, but both my Jets are original untouched circuits. i should re-cap them, i know, but the sound...
Cat Museum, ACME, Malcolm Mooney, Magic Gas, Dream Apes, The Cooling Time, Kind Hearts and Coronets, Quarks
- Flurko
It looks like I will never be able to take a clean picture in the dark practice room we play it, but my "band" setup seems pretty stable now :
Last time I brought my Epi SG, the EHX power amp pedal was way too dark. Now with the lipstick-equipped 7 string, it balances perfectly the shrillness of some of the high notes. The cheap American Sound pedal (sold as Harley Benton here, and as Joyo and many other brandings elsewhere) is very usable for some quick EQ and adding just a little warmth. Funnily the DS2 provides a very light overdrive when it's fed light output lipsticks, allowing me to use my broken behringer overdrive for huge wall of fuzz/sunn-ish drone freakouts.
- 46346
Ursa Minor wrote: ↑Wed May 11, 2022 8:38 pm^ Amazing setup.How are you liking the Echolette? Was it tough to get it going? I also scored one last month
but I haven't fired it up yet. Its in great shape but needs a a power cable, new loop, and a fuse. Hoping it won't be a massive undertaking beyond those relatively simple fixes.
i got lucky with this Echolette, it's fantastic. it's my 2nd attempt... the first i bought on eBay for cheap enough, but haven't gotten playback from the
tape yet, even though it's seen some service work. it does sound great as a preamp, worth what i paid, but i'm overdue to get it to a tech who i met who understands these units. he's two hours away...
but i encountered this 2nd Echolette at a pawn shop while traveling, i was able to plug in and hear the tape work. it was warbly and messy, but i
could tell that it wasn't too far off. i cleaned and lubed all the rolling parts, and got a new pinch roller. and cut some new tape from my old stock.
it can really go over the top with saturation and oscillation, or just be beautifully lush in tone over countless repeats. it has the original Telefunken tubes and they are good and strong.
so, the short answer is: One has been difficult, and the other was easy. i'm concerned about your fuse, sometimes a missing fuse signals that
something went wrong and somebody pulled it but never figured out why it blew.
but maybe it never blew, maybe it got knocked out during storage.
i just saw your PM, and will respond about the fuse type. my first, unrestored unit is here at home, and i can go take a look...
- hulakatt
I had a Jet J12D for a few years, found it out by the curb for the trash one day while delivering mail and took it home. Needed a new fuse and a 3 prong cord but everything else was 100% untouched, original and needed nothing. All the caps checked out solid and worked great. The only issue was I never could get the trem to work. Apparently it was one of the those oddball preamp tubes Ampeg used that was flaky enough for the trem to not work but everything else was great. Didn't feel like paying through the nose for a NOS tube and sold the amp instead.46346 wrote: ↑Sun May 15, 2022 11:45 pmJonesie wrote: ↑Thu May 12, 2022 12:39 pmSo the Barbershop goes well with the Ampeg thing? I have an old Jet that I love and it's definitely a bit finicky with OD's. I'm using a double rock right now, which sounds fantastic, but I'm always looking for something else. Is the Barbershop a Morning Glory / Bluesbreaker real low gain type thing?garyfanclub wrote: ↑Thu May 12, 2022 10:40 amKeeping it super simple this afternoon…
She/Her
- Unicorn Warrior
- hulakatt
- luau
- Admin
It's wine red and is pretty dark, but the light in my apt is crap as well. Thanks, it's 10.5 lbs, has a slight twist in the neck, and needs a fret level, but isn't in bad shape. I've rewired and it and have an unoriginal set of period Gibson pickups in it but the originals are going back in whenever I get around to it. I've had it since '85 so we have a big anniversary coming up in a few years.Unicorn Warrior wrote: ↑Tue May 17, 2022 6:31 pmIs that wine red or a rich brown?
Either way, I absolutely love Customs from the 70s and this one looks fantastic
I like them as well and wish I would have picked up a cherry sunburst model when prices were better.
- Unicorn Warrior
It probably doesn’t help that I was looking from my phone. Wow. Yes, a very long time. A wine red custom from the 70s is one of my dream guitars. Cool that’s it’s been with you that longluau wrote: ↑Wed May 18, 2022 12:44 pmIt's wine red and is pretty dark, but the light in my apt is crap as well. Thanks, it's 10.5 lbs, has a slight twist in the neck, and needs a fret level, but isn't in bad shape. I've rewired and it and have an unoriginal set of period Gibson pickups in it but the originals are going back in whenever I get around to it. I've had it since '85 so we have a big anniversary coming up in a few years.Unicorn Warrior wrote: ↑Tue May 17, 2022 6:31 pmIs that wine red or a rich brown?
- sal paradise
GF has gone to Primavera. Little amp & electric sneak downstairs for the weekend
- hulakatt
Thos little DSL amps are monsters and way underrated! I had a DSL201 for way too short a time.sal paradise wrote: ↑Fri Jun 03, 2022 8:31 amGF has gone to Primavera. Little amp & electric sneak downstairs for the weekend![]()
She/Her
- sal paradise
I’m kinda ambivalent about it- I wish it were a bit more like my old jcm2000. At the same time I got it for £120 or so- I really can’t complain & it kicks the ass out of any other practice amp for that kinda price.hulakatt wrote: ↑Fri Jun 03, 2022 10:01 amThos little DSL amps are monsters and way underrated! I had a DSL201 for way too short a time.sal paradise wrote: ↑Fri Jun 03, 2022 8:31 amGF has gone to Primavera. Little amp & electric sneak downstairs for the weekend![]()
