A simple phase switching pedal?
Everyone needs a stompbox.
DeathJag
Post by DeathJag » Mon Jul 05, 2021 9:45 am
Hello again! I like to play with two channels, a wet and dry. Using separate amps it’s no problem, but sometimes I wish to use a single two channel amp, and the channels are out of phase. I am wondering if there is a pedal I can throw on one side to reverse the phase?
That Radial Bigshot ABY seems like a cheap-ish big giant thing that would do it, but I would love something smaller. I realize that pedal is passive and can work unplugged.
I contacted Saturnworks to see if they can make one for me, but it can’t hurt to ask the board!
Dan
Beebe
Re: A simple phase switching pedal?
Post by Beebe » Mon Jul 05, 2021 2:53 pm
I just found a list of pedals that flip phase here (you may have a pedal laying around you can try).
https://www.thegearpage.net/board/index ... se.796444/
Without music, life would be a mistake.
DeathJag
Post by DeathJag » Mon Jul 05, 2021 3:20 pm
Hey thanks a lot for this! I don't have that many pedals and none on that list, ah well. I did contact the Saturnworks fellow who told me he has a buffer pedal with phase switching, and the the passive way to do it involves a transformer and is larger. It was only $50 so I ordered it. Seems like a lot of work to make a passive one that only does that one thing!
Beebe
Post by Beebe » Mon Jul 05, 2021 4:42 pm
Sounds like a good way to do it. Hope it works out for you.
Zork
Post by Zork » Tue Jul 06, 2021 12:55 am
An EHX LPB-1 (or any other one transistor boost) set to unity would switch the phase when engaged. If you want a splitter with a switchable phase inverter have a look at the Palmer PGA03. It also has a switchable ground lift. I'm using it in my two amp setup and to me it's a perfect solution: Noisefree, small, simple and rather inexpensive.
marqueemoon
Post by marqueemoon » Tue Jul 06, 2021 6:13 am
I looked at that Palmer for a while. Good to know it’s solid.
If an isolation transformer is needed here’s a cheap but decent looking one I found in my searches:
https://www.edcorusa.com/buzzbucker-2
DeathJag
Post by DeathJag » Tue Jul 06, 2021 7:29 am
Hey this looks pretty nice! I like that it uses a transformer. I would love to find a straight up passive pedal that does phase switching. I dunno I guess I like passive pedals heh. But that Palmer looks pretty dang perfect... I'll check that out if the Saturnworks one doesn't work or has too much noise.
No one's used the Radial Bigshot ABY? That is large but it can run without power, so perhaps ultimately that's my best option. I guess it would be dumb for a manufacturer to make a big passive transformer pedal that only switches phase, I mean, who would want that?!!
Dan Izen
marqueemoon
Post by marqueemoon » Tue Jul 06, 2021 8:19 am
Dan Izen
The Lehle P Split will do it, but pricey.
jorri
Post by jorri » Tue Jul 06, 2021 3:19 pm
Do polarity reversing connectors/cables exist for guitar jacks? Thats the simple option when using microphone xlr. If you dont need to switch the phase quickly.
Shadoweclipse13
Post by Shadoweclipse13 » Mon Jul 19, 2021 8:55 am
Dan Izen
Lehle P-Split was my thought. I've got 2 and they are fantastic. They are passive and fairly small. Since they don't have a footswitch or anything like that, you could mount it to the underside of your board as well...
DeathJag
Post by DeathJag » Mon Jul 19, 2021 12:43 pm
That’s very cool about the L split. I guess some Radial pedals do it passively also.
In the meantime, $50 got me this Saturnworks pedal that takes 9 volts and only switches the phase. It works great! I would like a backup that is passive for the future tho!
Thank you all so much for your replies!
Dan
DeathJag
Post by DeathJag » Fri Nov 05, 2021 3:38 pm
Update: I used the Saturnworks with success, but I wanted a second option that was passive. So I picked up a Radial Bigshot ABY and I LOVE IT SO MUCH. The tone suck from being passive must be my thang, because it was instantly a more awesome tone. Instantly. I play surf, and all of a sudden I was hearing a true, *amazing,* classic surf tone. I played an avri jag through a ‘62 Twin and a ‘64 6g15 - you’d think those two would be enough. But it wasn’t until the Bigshot (that I first tried last night) that I just started getting goosebumps. Over and over. I was messing up my playing because truly, I was entranced by the tone. I mean, it was magical.
How awesome is it when you give yourself goosebumps?!!
I am so glad I tried the passive route!
Dan
BTL
Post by BTL » Fri Nov 05, 2021 3:56 pm
It took me a minute to understand the issue, but now I get it and I'm glad it worked out!
Owner, Lowe Custom Guitars
