Boss TU-3W vs Strobostomp HD
I'm in the market for a new tuner for my home board. My venerable old TU-2 that's been the workbench tuner is starting to crap out so I'm going to swap over a Pitchblack I have on the board for those duties and put something in it's place.
I like a buffer at the front where possible so both offer those. The Strobostomp has a big screen (good for my aging and often tired eyes), the Boss is likely bulletproof. I've only used strobe tuners briefly and they do kinda confuse me but I expect it's a fast learning curve so that doesn't scare me. I like that the Strobostomp can be tweaked so you can set up a 'sweetened tuning' - which I've done for years on the B string (very slightly flat).
So, anyone here using or used the Strobostomp HD? Opinions? TU-3W? I'm guessing thoughts on those will be predictable as Boss is, rightfully, highly revered.
Re: Boss TU-3W vs Strobostomp HD
On my Half Tail board I use a Polytune 3 Mini in strobe mode. That’s a pretty good way to go IMO.
Strum all strings to see which ones are out and make big changes, then use the strobe to fine tune.
I think on the Strobostomp the buffer can be switched on and off, which could be a consideration when using germanium fuzz, etc…
Strobe tuning live can be a little fussy. On my other board I use my ancient TU-2, and it’s certainly good enough for live use. With strobe you never get that “yep, you’re in tune.” certainty.
I tried a polytune and ended up just reverting to old habits of individual strings (odd tunings doesn't help).marqueemoon wrote: ↑Sat Mar 23, 2024 9:56 amOn my Half Tail board I use a Polytune 3 Mini in strobe mode. That’s a pretty good way to go IMO.
I think on a the Strobostomp the buffer can be switched on and off, which could be a consideration when using germanium fuzz, etc…
Whatever tuner I pick is going on my home board. For live I just use a TU3 and be done with it...there's only that and a BD-2 on there.
- zhivago
Strobostomp all the way for me, I love the sweetened tunings it offers.
The one thing that has to be noted though is that it takes a split second of the Strobo to start tuning and mute the sound. I think it is related to the relay of the whole true-bypass switching system. Doesn't bother me, but it is definitely there.
I just watched a video of someone bemoaning the relay delay. For home use, I'm not that bothered.zhivago wrote: ↑Sat Mar 23, 2024 10:02 amStrobostomp all the way for me, I love the sweetened tunings it offers.
Glad you chimed in on this as I know we don't have wholly dissimilar setups.
- zhivago
Oh yes, for home use it is no problem at all.
I have been into the whole sweetened tunings thing for many years...since I got a Strobo 2 probably 15 years ago or so.
I am going to pick up the headstock tuner they brought out soon as well.
- Dr Tony Balls
If you can stomach true-bypass the Sonic Research tuners are awesome and very accurate which is great if you'll also be using it for setting intonation.
Instagram: thetonyballs
Does that 'flat' button allow you to set it for Eb standard but still display proper flats (or just adjusted to display regular EADGBE) and not the, infuriating, D#G#C#F#A#D# nonsense?Dr Tony Balls wrote: ↑Sat Mar 23, 2024 11:46 amIf you can stomach true-bypass the Sonic Research tuners are awesome and very accurate which is great if you'll also be using it for setting intonation.
*Edit: I see it does, that's good. They sell direct, I think it works out less than a TU-3w
- spiffy chap
I've been using Strobostomp since the 2nd stomp model came out, about 4 iterations ago. Still own it and have a non slim HD.
I use the GTR sweetened tuning and dig it.
One thing that isn't mentioned enough is the screen's high visibility in almost any gig setting: outdoor, indoor, bright lights, no lights, etc.
