how do you get this effect?
Hi, i heard this guitar effect on a Klaxons track called gravity's rainbow, the guitar totally freaks out for a few seconds in the middle check it out http://www.myspace.com/klaxons you can hear it really obviously at about 1:14. what is it? I want it!
- Pumpkin
Re: how do you get this effect?
EH tube zipper by the sounds of it!
- mjet
Might well be. Here are some samples from the EH website:
http://www.ehx.com/ehx2/Default.asp?q=f ... 5FMatthews
- chrisjedijane
It sounds to me like someone messing around with the delay time on a delay pedal while the signal's being fed through, with the feedback set just low enough so that it doesn't self-oscillate.
Those Tube Zipper sound samples sound like the TZ is modulating the signal in a similar manner to a phaser/chorus, whereas on the Klaxons tune there is definite delay modulation going on. Does this qualify as Granular synthesis in a digital delay pedal? I could never decide for sure.
- Pumpkin
I'd say its turning a knob on a TZ (i think,its one of those 12ax7 pedals anyway),on EH site, i think its Fruciante that does it,who ever it is sounds identical.Could be a delay knob tho,sounds like that too!
- mynameisjonas
- Admin
that´s exactly what it sounds like to me too.chrisjedijane wrote: It sounds to me like someone messing around with the delay time on a delay pedal while the signal's being fed through, with the feedback set just low enough so that it doesn't self-oscillate.
- Jay
- Admin
I too think it's a delay oscillating.
Ok....ithink ill check the TZ pedal...be cool if you could rig up an expression pedal to it!
- Pumpkin
You can!
But it may just be a delay too!
